    shred
    need help getting ss crankset
    Im having trouble finding a freeride/dh SS crankset and needs to fit a 68 mm bb shell and 113 isis. It needs to be under $160 and i dont care about weight, This is my first single speed conversion i need some help on what i should get
    Reputation: scooter916's Avatar
    any triple or double ring crank will work, just remove the rings and add a SS specific ring(taller teeth with no shift ramps) and get shorter bolts or a bash/guide ring
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    SS spesific chainring is not nessessary. I have had no trouble with rampped rings and normal 9 speed chain.
    shred
    Well thats good to know thanks peeps
