Go Back   Mtbr Forums > Classic Mountain Bike Forums > Singlespeed
Reply
LinkBack Thread Tools Display Modes
Old 01-16-2012   #1
Rep: danraley41 is on a distinguished road
user gallery
Need help figuring out how to set bike up like the one in the picture.
So I am "Urbanizing" my SS Rigid 29er and can not figure out what bars these are and how to make it work with my stem and mech. disc brake levers. - Does anyone have any ideas? They look like mustache bars in other pics of this bike I've seen. - I'd really like to keep this as simple as possible and not have to change my stem and levers, but if I do any suggestions on some inexpensive ones would be great, thanks.
[IMG]
Source: flickr.com via Dan on Pinterest
[/IMG]
danraley41 is offline   Reply With Quote
Old 01-16-2012   #2
drofluf's Avatar
Rep: drofluf will become famous soon enoughdrofluf will become famous soon enough
user gallery
What disc brakes do you have?
Hard to tell from that picture but it looks like a road style brake lever?
If it is then you'll need a road style disc calliper such as the BB7.
__________________
More ears than gears
drofluf is offline   Reply With Quote
Old 01-16-2012   #3
user gallery
I just have Tektro Mechanical Discs Brakes, nothing fancy. I'm fine keeping my brake levers mtb style if I can find a bar they'll clamp to I like. I just saw some different Nitto bars and Soma bars but not sure if they are exactly what I want, or wide enough I have my current flat bar cut down to about 24 inches, or 609.6 millimeters roughly end to end. I also don't mind modifying a bar if needed, I'm pretty handy so that would not be a problem if anyone has any ideas on that too. What I really want is something without a lot of drop and with the ends swept back straight. I'll be wrapping them with grip tape and I'd like to just mount my current levers on the flats if possible like they are now.
If I have to change my stem any ideas on some inexpensive ones to look at? Looks like most of the bars I see out there this style are 25.4mm clamp size, which I don't mind, the 31.8's are really kinda fat and ugly looking IMO.
Old 01-17-2012   #4
Rep: Moozh is on a distinguished road
user gallery
Those bars look sort of like time-trial or bullhornbars only turned toward you. Should be able to find a set in eithere 25.4 or 31.8 or whatever mtb stem you have. Hope you dont have a stubby stem..
as an alternative some cool moustache style bars are 31.8mm FSA Metropolis bars..I have a set and really like them on my urban SS...I have a set of hinged clamp bmx brake levers (Tektro XL751's) pulling caliper road brakes so I dont know if they are suitable for mech disks..but they do mean you do have an easy way to attach and fasten the brake levers no matter how swoopy the bars you choose are.
Moozh is offline   Reply With Quote
Old 01-17-2012   #5
A Gentleman and a MTBR'
stubecontinued's Avatar
Rep: stubecontinued will become famous soon enough
user gallery
I'm pretty sure those are just NITTO mustache bars. Check out velo-orange and SOMA for tons of bar/stem options, they'll also indicate whether you need road levers, like the picture; or you can use mountain levers. The clamp diameter is different for both. I think getting townie bars for MTB levers and flipping them might work for you..
__________________
StuBeContinued
stubecontinued is offline   Reply With Quote
Old 01-17-2012   #6
user gallery
@Moozh Yeh I kind of thought that too then I found another pic and they are moustache bars, but I like and had already thought of the idea of flpping some TT or bulhorns and cutting them off if they stick back at me to long to where I'd basically just have enough room for my hands on them and then mounting my levers on the flats. I def don't like my bars I have now especially for urban riding, pretty uncomfortable and I really don't like the 31.8's to fat. So if I can find an inexpensive stem and some bars I like in 25.4 that will work with my levers then I might just go that route, I'm just trying to keep this inexpensive and as simple and un-flashy as possible.
Old 01-17-2012   #7
Rep: FKMTB07 is an unknown quantity at this point
user gallery
In the pick are Nitto Mustache bars (that little red stripe near the stem clamp area indicates they are the heat-treated version), Paul brakes (Neo Retro up front, Touring out back), White Industries cranks, and Schwalbe Big Apples. The frame looks to be custom or heavily modified.
If you want to run your Tektro mechanical disc brakes with road levers (which is what is on the Nitto Mustache bars you see), you'll need Tektro R520 levers, which are road levers that are long-pull and will work with mtb brakes (including mtb mechanical disc brakes).
Good luck and post pics.
FKMTB07 is offline   Reply With Quote
Old 01-17-2012   #8
user gallery
Here are the other pics I saw of that bike, even though they look a little different than the first one I put up.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
Old 01-17-2012   #9
Ovaries on the Outside
umarth's Avatar
Rep: umarth has much to be proud ofumarth has much to be proud ofumarth has much to be proud ofumarth has much to be proud ofumarth has much to be proud ofumarth has much to be proud ofumarth has much to be proud ofumarth has much to be proud ofumarth has much to be proud of
user gallery
They guy has some mustache bars going, but you can't replicate the stem because he has a threaded nut job. But you can buy pretty cheap kalloy unos from universal cycles. I had one at one point and it was fine.
Pay attention to stem length- the mustache bars will have you reaching more than your current bar, so if you already have a short stem in order to stay comfortable...
You can use road levers if you buy Tektro RL520s. They have longer pull for disc/linear brakes. Then add schwalbe Big Apples/Supermotos and you are done. You have a bike that you wont want to take offroad.
And he has a 26" bike...
umarth is offline   Reply With Quote
Old 01-17-2012   #10
user gallery
I think these just might be the ticket! VO Porteur Handlebar - Handlebars - Components
I'll just have to get a new stem, but they will work with my levers, hate they are all shiny, but I'm gonna wrap them in black bar tape so really does not matter I guess.
Any ideas on the right stem? this is my bike;
Save up to 60% off new Mountain Bikes - MTB - Gravity 29Point1 29er Mountain Bikes
Here are the specs on the brakes, headset, handlebar and stem now;
Brakes Tektro Novela Disc Brake 160mm Rotor front and rear
Brake Levers TEKTRO RS-360A ALLOY BLACK, Brake Levers
Headset CaneCreek VP-A42E Sealed Bearing threadless 1 1/8 in
Handlebar Black Finish Aluminum 6061 T6, 660MM (31.8mm)
Stem Black Finish Aluminum threadless
EXT:90MM(15.5"~17.5")x10 DEGREES, ALLOY BLACK
Old 01-17-2012   #11
user gallery
That's *****in bike.
I used to run these on an older Trek 950.. they work with your current levers, are inexpensive and comfy.
Here's another option.
__________________
StuBeContinued
Old 01-17-2012   #12
user gallery
ooops. preempted on the porteurs.
__________________
StuBeContinued
Old 01-17-2012   #13
user gallery
yeh those are the two I was looking into most. I like the shape of the VO porteur's better, but they are about two inches narrower than the Soma oxford's, prob would not be an issue. I really like the lines/curves of the VO's def sweet looking, but the Oxford's inverted so they have a drop instead of rise is nice too, just seems like they have less "flat area" to clamp my levers to and the they are little longer in the swept back grip area, but I could always chop that down too, hmmmm decisions.....lol
Old 01-17-2012   #14
user gallery
I really like the look of the porteurs, the curves are really pleasing to the eye. The oxfords were BIG, really long on the grip area. I used them because I was using bar-end shifters. I think for a bike that's primarily concerned with being sexy maybe go with the VO's? If you do, let us know how they work..
__________________
StuBeContinued
Old 01-17-2012   #15
user gallery
Yeh stem length is what I'm concerned in finding so it feels/fits right. I've already got some Schwalbe HS 338's in 28x2.35 on the way, should be here Friday.
I really think I'm not going to go with Mustache bars like he has and go with either the VO Porteurs or the Soma Oxfords. I don't want to exactly copy his bike anyways, but it's just the first bike I saw pics of that is what I've been wanting to do to mine since I thought of it.
I live in Florida so sadly our off-road options are limited and not all that fun IMO on a rigid SS, other than the grass trails around the single track which is really rooty and technical, I like fast and rolling better, also nothing closer to me than about an hour and half away so not that convenient to go ride anyways. We do have some great paved trails right where I live and I'm really close to the beach so I like to ride out there so this type of a setup would be much better for me really.
Yeh I realized his was a 26", I had a 26" cruiser I sold to buy this bike, I really like the 29er other than there not being as many tire options to choose from, but when those big wheels get to turning the momentum they maintain is much better especially in the SS than my Cruiser, or my old 26"mtb I used to have and I can't wait to get the HS338's on there should be even better, other than I'll prob spin out faster since I'm running 33x18 now which might be a down the road project to change after I get this all setup and done and see how it works, since it will be mostly on-road vs off-road, but I'd rather spin out than crank my knee so IDK.
Old 01-17-2012   #16
user gallery
Thanks I def will and will post up some good bike-porn of it too, I'm trying to figure stem sizes now to go with the VO's and then find an inexpensive one to order.
Old 01-17-2012   #17
user gallery
I somewhat done this in the past to a couple of my bikes..my modest attempt nothing major but.
On-one Mary bars 25.4. schwalbe big apple 2.35", surly tensioner, SS road cranks (miche advanced 49t..hadda change out the spindle to a wider one to get clearance as the chainwheel and driveside crankarm made contact with the chainstay)..old setup for a summer two years back..
same bike with FSA metropolis and short stem..quite the bomber..
Or if you are not married to the moustache idea, hows about some simple arc'd bars? not on a MTB but just so you can get an idea..
not the best pic but this is how I have my steamroller set up at present:
Those VeloOrange bars look like you've found the antidote to me..they look fantastic. Just be sure to get the right size for mtb brake levers so that you'll have no issues using your disk brakes. The stem clamp area states that i's 25.4 so you should not have any issues whatever locating a mtb stem to work..
Old 01-17-2012   #18
vaultbrad's Avatar
Rep: vaultbrad has a spectacular aura aboutvaultbrad has a spectacular aura about
user gallery
Here is another bar option from Soma. They make another version of the mustache bar for smaller diameter mountain levers and 25.4 stem. You could get a reply nubby stem and those bars and be done with it.
Soma 3 Speed Moustache II Handlebar
vaultbrad is offline   Reply With Quote
Old 01-17-2012   #19
Sweep the leg!
Caffeine Powered's Avatar
Rep: Caffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant futureCaffeine Powered has a brilliant future
user gallery
I have a set of those bars on my SS commuter. I had to shim Dura Ace road levers but they're fine with old XT cantilevers. Some folks call the bars "Priest Bars" but mostly they're referred to as "Mustache Bars."
__________________
Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
Caffeine Powered is online now   Reply With Quote
Old 01-17-2012   #20
user gallery
Yeh the VO's are really what I had pictured in my head as wanting, so It'll most likely be those in the size for my current levers with a new stem. Just trying to find a decent inexpensive stem in black and figure out what the right length is so the fit/reach is good. I don't mind if if stretches me out some I used to a be a roadie so that's comfortable to me, but at the same time I want it to be comfortable just cruising a path lazily.
Old 01-17-2012   #21
umarth's Avatar
user gallery
Porteur bars are really narrow. Just saying...
Old 01-17-2012   #22
user gallery
Yeh I saw that and that concerned me some so I just hopped on my bike and held a tape measure across my bars to see what that would be like and I think it'd just be to narrow, not a lot of control, especially at with some speed. Does anyone know of any bars similar that are a little wider?
Old 01-17-2012   #23
user gallery
Alright from what I can find I think I need to go with one of the following bars below. While the Portuers have more of the "look" I had in mind I think they are just gonna be too narrow. Noth of these Soma's say they are 54cm, which is only about 2.3" narrower than what I have my flat bar chopped to now so that should not really be an issue I don't think.
3-SPEED MOUSTACHE II BAR
3-Speed Moustache II Bar | SOMA Fabrications
or
OXFORD BAR
Oxford Bar | SOMA Fabrications
Depending on which you think would be best maybe you could give me an idea on a stem length?
Old 01-17-2012   #24
vaultbrad's Avatar
user gallery
The specs you posted re your current setup say 90mm stem? Do you feel stretched out, cramped or just right? That will tell you how to size your stem. With the mustaches Id make the "perfect" position between the ends of the bars and the "hooks" to make for brake accessability in the traditional location and hand position versatility. Unless you put your levers on the straight sections as you would with the oxfords or other "northroad" style bars. Then you would want to put the middle of the straight sections the "perfect" position witch would require a longer stem. Get the bars through your LBS and then ask them to help you size the stem. They probably have a box full of stems of all shapes and sizes that will help you find the right combo of length and rise/drop. Then you can ask them to get you the stem you want in those dimensions.
Old 01-17-2012   #25
user gallery
Personally I like the oxfords over the moustache, I've never been able to feel right on a moustache bar, the oxfords were comfy for sure, and flipped and chopped they'll look pretty bada$$
__________________
StuBeContinued
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Thread Thread Starter Forum Replies Last Post
I built a singlespeed. help me with this tensioner? CommuterBoy Singlespeed 72 02-08-2012 08:43 PM
New FS bike for the kid surftime Families and Riding with Kids 12 01-31-2012 07:08 PM
which bike and tire set up would you choose ? jincardona All Mountain 1 01-16-2012 08:13 PM
Colorado Fat Bike January Social RIde juansevo Colorado - Front Range 4 01-14-2012 07:04 PM
More Bike Mag atricles in Brevard Logover North & South Carolina 1 01-10-2012 08:54 AM
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
