Results 1 to 3 of 3
    Need help converting a gearie to SS...
    I am working on converting my Homegrown to a SS. I am using a Gusset 1-ER and there is a little rattling after I have installed it one the hub. Has anyone used this product and run into this problem? There isn't a lot of room, just enough to be really annoying. Is there anything I can use to take up a little room without messing it up? Thanks for the help.
    Reputation: SCRAMPY's Avatar
    Go to LBS
    The local bike shop should have a thin spacer or two, I think the .5mm ones are steel and have a notched appearance.
    They may try to hose you for the alloy 1mm if they are low on stock.
    Older cassetts often came with a .5mm steel one.
    i worship Mr T
    Reputation: *rt*'s Avatar
    Quote Originally Posted by TXrider
    i had the same problem. i went to my lbs and found a spacer the right size to fill the spake and take away the rattle. works like a charm.
    rt
    "where are you not going so fast?" (question asked to cyclist on a trainer)
    *rt*'s fabulous blog
    mm blogging
  1. Converting my HT to SS
    By DobeManSS in forum Singlespeed
    Last Post: 11-16-2004, 05:37 PM
  2. Converting to SS
    By bung in forum Singlespeed
    Last Post: 11-07-2004, 02:17 PM
  3. Replies: 5
    Last Post: 05-11-2004, 06:57 AM
  4. Keep a gearie, or go full SS? Need some opinions.
    By GirchyGirchy in forum Singlespeed
    Last Post: 04-13-2004, 05:29 AM
  5. help me with converting to ss......
    By oneill77 in forum Singlespeed
    Last Post: 03-13-2004, 06:12 PM
