Results 1 to 7 of 7
    I like rigid MTB.
    Reputation: edle's Avatar
    New question here. Need help in chossing the correct size single speed front chainring for a 29er.
    32T(front) + 20T(back) in a 26er = ??T(front) + 20T(back) in a 29er.
    I felt really comfortable in the above single speed 26er gear ratio now. I need to know which front chainring size can give me the same feel as the 26er if my 29er has 20T in the back.
    Thanks.....
    Reputation: J.B. Weld's Avatar
    18 t would be the closest match, would give you a slightly bigger (harder) gear. 33 x 19 would be nearly exact.
    hispanic mechanic
    Reputation: sslos's Avatar
    30t. But I'd try the 32x20 first, just 'cause you've got it.
    Los
    "Shut up body and do what I tell you."
    Jens Voight
    http://teamjva.com/jens-voigt-soundboard/
    ssios is right, I got it bass ackwards. You could keep the ring and fet a 22 rear cog and be close too, you're at about 42 gear inches now. BikeCalc.com - Bicycle Gear Inches Chart
    I like rigid MTB.
    Thanks for the info.
    I have 32T x 20T now in the SS 29er and I would like to buy the front chainring once since experiment with different front rings will be expensive.
    Other option....If front ring is 32T, then which rear cog should I get.
    hispanic mechanic
    Quote Originally Posted by J.B. Weld View Post
    Quote Originally Posted by edle View Post
    As J.B. Weld said, 22t will keep you close in gear inches, but I've found that a slightly larger gear can be just fine with the switch to 29" wheels. I'd avoid switching chainrings for a couple of reasons- smaller rings are hard to find, they're more expensive, and they'll wear out faster.
    I assumed since you were asking about chainrings that you had a high dollar freewheel like the White Industries.
    Los
    Jens Voight
    I like rigid MTB.
    The 20T cog is Chris King. Too bad CK don't have 22T. I will try out the 32T-20T combo and see how it feels.
    Thanks everyone for the valuable info.
  1. Single chainring up front?
    By daverach2478 in forum All Mountain
    Last Post: 01-18-2013, 06:40 PM
  2. Single speed chainring as chain control
    By Slash5 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2012, 05:19 PM
  3. Chain Keeper or SIngle Speed Chainring
    By Dalton in forum Commuting
    Last Post: 04-05-2012, 12:16 PM
  4. Single Speed Crankset Size?
    By Your Bike Sucks in forum Women's Lounge
    Last Post: 06-01-2011, 01:32 PM
  5. Replies: 0
    Last Post: 04-07-2011, 03:29 PM
Hot Deals
Contests
Latest Mountain Bike Articles
