Results 1 to 32 of 32
    Reputation: edouble's Avatar
    Need chain tensioner advice!
    [B][/BI have fallen in love with rigid ss riding. So now I want to convert my favorite bike to a ss. Its a custom Ted Wojcik 29er frame with 17.5in cs. I was wondering if there is a "magic gear" for that particular length?. I have no idea how the magic gear is determined. Right now my ss bikes are 34x20. If I cannot run a "magic gear" then I need a really clean, unobtrusive chain tensioner. I saw one that mounts on the front instead of the rear. The "YESS LABS ETR/B chain tensioner". Has anyone used this device?. If so please do share your thoughts. Any other really clean systems out there that I need to know about?. I hate the way most look, they destroy the super clean ss lines of the bike imho.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Jan 2009
    measure your chainstay length and use this to calculate what magic gear might work best- http://eehouse.org/fixin/fixmeup.php there's no guarantee that the calculator will be perfect, but it's a good place to start.
    one chain loop
    Reputation: fishcreek's Avatar
    for more accurate result, measure the chainstay in cm and use the calculator mentioned above.
    everything sucks but my vacuum cleaner.
    Dive Bomber
    Reputation: jackspade's Avatar
    From my experience so far so good tensioner that work for me is the one on BB. Less chainskip just need to do something about the noise - I wrap the roller with velcro and it works great silencing the noise.
    On the RD hanger:
    The spring type is good as problem solver especially for ovaled crank, it keeps the chain tension uniform. But the cons is you cannot adjust the tension which is makes the pedaling heavier except for surly(try to backspin to see the resistance).
    The cons is the same like you're using RD, if it hits something it could broke. This also goes for fixed tensioner too.
    What I don't like about sprung RD tensioner it doesn't work for smaller cog less than 15T except if you can adjust it too push-up so more teeth to be wrap by the chain.
    CMIIW.
    Thanks for the replies...
    Guys. I will try Fishcreek and Mack_turtle's suggestions first. If that doesn't work out then onto Jackspades suggestions.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Reputation: namkrad's Avatar
    If you have an iphone you can check this app out.
    Pretty good stuff...
    Bike Gears, the Bicycle Gear Calculator app for the iPhone and iPod Touch
    /J
    Oaktown Honkey on Strava
    I don't like the whole rear der tensioner either, but it works well.
    I have 3 bikes, of course the cheapest one w/ tensioner is the least problematic. Go figure.
    Reputation: Martin6's Avatar
    pm sent on tensioners.
    Nope, HTC EVO
    Quote Originally Posted by namkrad View Post
    /J
    in an iPhone world!, LOL.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Got it...
    Quote Originally Posted by Martin6 View Post
    PM replied.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    surly inbred
    Reputation: TroutBum's Avatar
    Magic gears are a temporary solution to a permanent problem.
    I ran a Rennen for a year with zero issues. If I had to do it again I'd have a go at the BB mounted styles like the YES which makes dropping the wheel helluva lot easier.
    Reputation: henrymiller's Avatar
    Quote Originally Posted by TroutBum View Post
    FYI:
    My Ted Wojcik would not work with the Rennen due to the Ritchey dropout. It would take some serious grinding or dremel work to fit.
    Roscoe's Chicken 'n Waffles
    Aug 2010
    How about I sell you my White Ind. ENO HUB and disc brake adapter and then there's no need for an "ugly chain tensioner" hanging off your bike... They work great, I have an 21t WI cog on there as well......anybody....anybody.....? Both of my bikes have sliders...no need for this anymore....
    Quote Originally Posted by pedal-man View Post
    He doesn't do disk brakes.
    Turn off the TV
    Reputation: SMT42's Avatar
    Nov 2006
    try a 1/2 link
    I keep losing the trail
    @Pedal-man: I do discs... how much are you asking for the ENO setup?
    Dive Bomber
    You can use halflink implant like this.
    This is my scott voltage YZ1 430mm chain stay length works with 24x15 and 22x15 just maybe it will work with other even-odd teeth combination - haven't try other ratios.
    I don't really...
    Quote Originally Posted by jackspade View Post
    understand how this thing works. I am looking at it but its not making sense to me.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Dive Bomber
    Sorry the pic is too small.
    Notice is on upper part of the chain there's a yellow/gold link that's a halflink.
    I use one halflink for shorthen the chain, so it's basicly an implant - instead of using the a whole halflink.
    I use this trick also for my adjustable drop out bike to keep the chain length short enough.
    Aug 2010
    1/2 links make noise ( "chink" or "click") as you spin the cranks, it becomes very annoying, within the first 2 rides...I pulled it off and threw it away.
    @ Hook - As for a price I will pm you. Thx.
    Jackspade, are you saying you use a SRAM powerlink how?
    Dive Bomber
    Quote Originally Posted by hoolie View Post
    No it's not SRAM powerlink.
    It's just ordinary halflink but I swap the roller with the one on the normal chain which is 3/32 - the halflink I use is 1/8 so I match it to 3/32.
    I am currently run 32x18 and this setting has no problem with chain skip compare to 22x13 but I believe the cause is not the halflink.
    63xc.com--How To | Magic Gear
    Aug 2010
    If anybody else is interested in the ENO set up....lightly used
    hub/disc brake adapter/21t WI fw/20t ACS fw/hub tool/SS KMC chain all for $250 obo.
    Ride on....
    I got your PM, pedal-man. Sorry I haven't responded- apparently my newbie post-count is still too low!
    There! That did it! PM sent...
    OP; have you considered EBBs that retrofit to standard BB shells? If you're not familiar with them, search "forward components ebb" or "exzentriker"
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Looks like Forward Components is down (has been like that for a while now). The only 2 remaining options that I know of are Exzentriker and Philcentric. By the way, I just received a letter from Exzentriker, they say that they will only be producing black and silver cups from now on. So if anyone wants other colors, now is the time to go searching.
    I decided to go with Yess ETR/B for the first attempt. Found that 34-17 looks promising (minimum theoretical chain length is just under 46") for 420 mm chainstays.
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
    I have considered
    Quote Originally Posted by Jonesy33 View Post
    But am not sure they will work with either my Bontrager Racelite or Truvativ Stylo ss cranks?. I am NOT going to buy a new crank.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    meow, meow.
    edouble,
    Exzentriker isn't going to work with GXP it seems. But Philcentric does have an option to support GXP.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    I bet you could have Wojcik replace the dropouts for not much more (maybe less) than some of these solutions. Circle A quoted me under $200 to swap dropouts a few years ago, but I was slow at work and did it myself.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    Quote Originally Posted by edouble View Post
    wish granted
    "Knowledge is good." ~ Emil Faber
    SpinDoctor
    Reputation: ClydeTheGlide's Avatar
    Still available? Pics?
    Ride on....
    Pedal-Man,
    Can't PM due to post-count. Can you PM me w/ pics and your email assuming the ENO setup is still available?
    Thanks.
  1. Replies: 17
    Last Post: 05-18-2011, 09:04 AM
  2. Replies: 10
    Last Post: 05-14-2009, 06:09 PM
  3. Chain Guide/Tensioner: Advice Needed
    By wadebigfork in forum Downhill - Freeride
    Last Post: 08-11-2007, 07:25 AM
  4. Chain Tensioner/Tugs advice
    By carbuncle in forum Urban/DJ/Park
    Last Post: 08-15-2006, 10:23 AM
  5. Chain tensioner advice(serious answers please)
    By snaky69 in forum Downhill - Freeride
    Last Post: 01-22-2006, 06:27 PM
