Results 1 to 8 of 8
    Narrow rear spacing on old Cruiser frame
    I have an old Schwinn cruiser. The rear spacing is something like 120. Does this sound right? Have any of you cruiser guys been able to stretch/ bend the frame to increase the spacing?? how'd ya do it?? I would like to build/ play with the frame using my MTB stuff.
    34N 118W
    Reputation: Hollywood's Avatar
    bmx
    BMX parts are your new friends. Don't touch that frame!
    try Danscomp.com or a local shop for a rear hub. I'm using the Shimano DX on mine, no freewheel, uses cogs like MTB and ez to change.
    Quote Originally Posted by nmcculloch
    Reputation: RickD.'s Avatar
    The old Schwinns have 110mm spacing, which is the same as a BMX hub. I built up my 67 Schwinn Racer with a Schwinn XS high flange hub, and have had no problems. Any 3/8" axle hub will do. Be careful not to get a 14mm axle hub. Those axles are too fat to fit into the old dropouts.
    wheel building
    Quote Originally Posted by Hollywood
    Can the wheel be built w/o dish? I may try it myself and do not have a dish guide.
    all hail der Fuhrer Bush
    no dish required for a single cog
    But, if you choose to spread the stays to accommodate an MTB hub, be aware that it's smart to re-align the dropouts afterwards. Just cold setting the stays to a wider dimension results in the dropouts canted inboard, which forces the hub axle to bow to accommodate their angle. Any decent shop has a pair of "H" tools (the Campy designation) that are used to gauge and align dropouts. It's like a 3-minute job and well worth doing if you don't like busted rear axles.
    What typ cogs??
    does the DX hub use the same cogs as, say, an XT freewheel hub?
    Cracker-magnon
    Reputation: gpsser's Avatar
    It uses DX/Novatec/Mosh cogs, or a King/Boone if you want to splurge. same splined interface like the XT, just set up to use a single cog is all.
    "Life is a F@#^ing story problem, get used to it - my son.
    34N 118W
    DX hub side note
    there is a DX "kit" available that comes with the hub and 3 or 4 cogs. Check shop or eBay.
    However, this is a freewheeling hub, i.e. no brake, and your cruiser probably doesn't have brake posts. In that case you may just want to use a coaster-brake hub, have posts brazed on, go fixie, or Fred Flinstone it at the stop signs
    HW
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. Thinking of custom frame, 29" frnt, 26" rear wheel...
    By schnapmaster in forum Singlespeed
    Last Post: 04-29-2004, 05:09 PM
  3. Some help, new SRAM rear transmission and new frame...
    By BanzaiRider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2004, 09:00 AM
  4. more mistaken 4-bar analysis
    By derby in forum Bike and Frame discussion
    Last Post: 03-11-2004, 05:20 PM
  5. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
