Results 1 to 26 of 26
    my raleigh XXIX fat bike
    just built this up
    Reputation: metrotuned's Avatar
    Holy moly. What's the size of the rear rim and tire? That must be at least 3.0? I knew the XXIX could fit fat tires through the rear chainstay but wow!
    Producer, Actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
    What is the rear rim/tire combo that you fit in there? It looks great.
    its a velocity p35 rim and a duro razorback tire 3.0
    Quote Originally Posted by jcufari
    26" p35 i assume? Unless Duro makes a razorback in 29 x 3.0?
    Mtbr Forum Sponsor - Homebrewed Components
    looks fun as hell!
    Its a 26"
    ISAR I just ordered a two piece cog for the raleigh pictured above
    Can the p35 duro combo fit the front factory unicrown fork?
    it will fit but it was super tight
    Reputation: arphaxhad's Avatar
    which way?
    Tight side-to-side or height? The factory fork on my 2009 is taller than those on the first couple of years'
    this might be fun to do!
    side to side. If the wheel got out of true it would def rub.
    Can you post a few more pics. Ive got a line on a frame and this would be a fun winter bike and much less expensive than going with the Pugsley that I really want but cant really justify.
    greenpea i just pm'ed you about the pics
    Reputation: proline69's Avatar
    Whats the actual diameter of tire when mounted to rim , i'd like to see if i can get them on my Stout
    Reputation: grinch's Avatar
    Hell Yeah!
    Love it!
    Teen Wolf
    Reputation: cr45h's Avatar
    sweet
    Reputation: Papa_Otter's Avatar
    Just found this old thread via search and am super stoked to see that it is possible to convert this bike as I have the same bike in stock form. jcufari what fork is that up front? It looks like a Surly but which one?
    ...Wait, that can only be a pugsley fork right?
    its the surly pugsley non offset fork. so it has a regular front hub. I would not suggest using a 26" rear rim. I had problems with the tire rubing on the chainstays. I have a 29" flow with a 2.4 mountain king out back now its awesome.
    That's too bad about the tire rub. Do you have a pic with the new set up? I assume the clearance is not a problem.
    Dec 2010
    Quote Originally Posted by jcufari View Post
    Its a 26"
    I know it's been a couple years now, but I was wondering if you've gotten your cog from HBC yet?
    I did recieve the cog. It broke, the aluminum pins sheared. He told me to send him back the pieces and a long time later he sent me a cog back that had my steel teeth mounted on a new hub interface. I have not remounted the cog.
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    Alright so this has been dead for a while. Has anyone tried the Surly Dirt Wizard? I have a red XXIX just like the OP. If a 3" fits then the Dirt Wizard should be just fine.
    A garage full of steel frames means happiness.
    Reputation: TheMachinist's Avatar
    Feb 2007
    I'm watching this too. I have the same bike and always dream of a fatbike.
    CS2
    CS2 is offline
    Quote Originally Posted by icantdrive65 View Post
    Same here, this is an economical solution or maybe a 29 +
    Reputation: bikeny's Avatar
    Wow, old thread! This might be a great frame for a 27.5+ conversion.
  1. Raleigh XXIX
    By jcufari in forum Fat bikes
    Last Post: 12-05-2010, 07:28 PM
  2. Anyone have a Raleigh XXIX they're not using?
    By Yogiwolfman in forum Colorado - Front Range
    Last Post: 11-14-2007, 03:16 PM
  3. Raleigh XXIX as a 1x9
    By surlyboy in forum 29er Bikes
    Last Post: 11-07-2007, 07:20 PM
