• 01-03-2013
    ovwok
    my diy 30 tooth 104bdc chainring
    Made mine own 30 tooth steel chainring for my XXIX dingle.
    <a href="http://www.flickr.com/photos/pattonmachining/8341301474/" title="Untitled by Pattonmachining, on Flickr"><img src="http://farm9.staticflickr.com/8504/8341301474_d66f3e832b.jpg" width="375" height="500" alt="Untitled"></a>
    kind of steam punk looking but works great.
    <a href="http://www.flickr.com/photos/pattonmachining/8340243743/" title="Untitled by Pattonmachining, on Flickr"><img src="http://farm9.staticflickr.com/8076/8340243743_9043827c5c.jpg" width="500" height="375" alt="Untitled"></a>
    30t #40 ansi blank
    <a href="http://www.flickr.com/photos/pattonmachining/8341294084/" title="Untitled by Pattonmachining, on Flickr"><img src="http://farm9.staticflickr.com/8359/8341294084_5de39ab888.jpg" width="375" height="500" alt="Untitled"></a>
    <a href="http://www.flickr.com/photos/pattonmachining/8340236819/" title="Untitled by Pattonmachining, on Flickr"><img src="http://farm9.staticflickr.com/8502/8340236819_d2fe5c4ddf.jpg" width="375" height="500" alt="Untitled"></a>
    <a href="http://www.flickr.com/photos/pattonmachining/8341299060/" title="Untitled by Pattonmachining, on Flickr"><img src="http://farm9.staticflickr.com/8359/8341299060_bf536140f7.jpg" width="375" height="500" alt="Untitled"></a>
  • 01-03-2013
    ovwok
    Run it on my dingle setup 26/22 low 30/18 high,same chain length. when I get to the top of a climb flip the bike over, open the quick release, raise up the wheel (vertical dropouts) and drop the chain to the 30-18 rings and ride on.
    <a href="http://www.flickr.com/photos/pattonmachining/8344144575/" title="Untitled by Pattonmachining, on Flickr"><img src="http://farm9.staticflickr.com/8074/8344144575_4018ce17ab.jpg" width="500" height="375" alt="Untitled"></a>
    <a href="http://www.flickr.com/photos/pattonmachining/8345199366/" title="Untitled by Pattonmachining, on Flickr"><img src="http://farm9.staticflickr.com/8358/8345199366_abfa4a958f.jpg" width="500" height="375" alt="Untitled"></a>
  • 01-03-2013
    zaskaranddriver
    Holymoly those are low gears. Sounds like some serious climbing. Nice work there!
  • 01-04-2013
    cdn-dave
    sweet, nice work!
    where did you source the blank?
  • 01-04-2013
    ovwok
    Originally Posted by cdn-dave View Post
    sweet, nice work!
    McMaster Carr, $26
    Its over 1/4" thick, after i found the center I bored a .750" hole in it and mounted it in the lathe on a 3/4" bolt with a center drilled in the end for support.
    (note the live center in one of the pics).
    I then shaved it down on both sides.
    The holes are threaded 5/16 fine thread.
    The bolts have a little .388"x.05" shoulder cut on them with a part-off tool
    You have to file a bevel on the crank spider for chain side-plate roller clearance.
    let me know if you need some dimensions because it not cut from the center line of the sprocket.
  • 01-04-2013
    ovwok
    Yes there are some grinder climbs around the San Fernando Valley.
    Some are 14-26 percenters. You have to learn to say "shut up legs".
  • 01-04-2013
    Harry Mackenzie
    Sorry for offtopic but I've been looking for something like this but why don't any companies make 30t x 104mm chainrings readily available?
  • 01-04-2013
    jetboy23
    In general, i think its a clearance issue. The spider for 104bcd is usually wide enough to interfere with the chain on the smaller chainrings. I think the groove/low point of teeth on my e.13 32t ring is right where my spider mounts on my Sram AKA. This is why spiderless rings will allow a smaller ring.
    Moving the chainring away from the spider will adjust the chainline. Generally this is fine on a SS setup, but, geared may mess up the ring spacing. There are possibly too many factors to get the spider clearance on all cranks/spiders to make it worth the supply for the minimal demand.
  • 01-04-2013
    Sparticus
    This is spot on. Good explanation.
    --sParty
  • 01-04-2013
    ovwok
    it moved the chanline over about 1mm, granny gear is still in the same place and i dont have any problems running 8 speed chain. there is a guy here on mtbr that makes a geared verison 30t with ramps out of aluminum google anderson 30t chainring.
  • 01-04-2013
    ovwok
    here a link to the tread:thumbsup:
    http://forums.mtbr.com/29er-componen...cd-485289.html
  • 01-06-2013
    cdn-dave
    Originally Posted by ovwok View Post
    McMaster Carr, $26
    Thanks for the info! I think the last time I looked at McMaster Carr, was for an M10x1.0 bolt to mount my DIY chain tensioner onto the derailleur hanger :thumbsup:
  • 01-06-2013
    J3SSEB
    Really nice! But don't try and go all homebrewed on us ;)
  • 01-06-2013
    RustyLeaf
    Tension?
    How do you keep chain tension? I dont see a movable dropout or chain tensioner:eekster:
