Results 1 to 5 of 5
    Oct 2012
    Most common chainline - 47.5mm or 52mm?
    I am trying to decide between White Industries hubs and Paul Components hubs for a new wheelset build. The WI ENO chainline is 47.5mm, while the Paul WORD chainline is 52mm.
    From measuring my bikes, it seems the WI lines up with the middle ring of a mountain triple, while the Paul lines up with the outer ring. Intuitively, it seems to me that most cranks I see have their single ring attached right to the spider, so it appears to me that the outer ring would be more common. Does that imply that the WI hubs are intended to be used only with bashguards, or am I missing something?
    Can I safely assume that the Paul 52mm chainline fits most popular SS cranksets? Sorry if this is trivial, but I am new to all of this, and googling never explained why WI chose 47.5.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by TooSteep View Post
    Basically you have it right.
    You can mount the ring in either position on most any "singlespeed" crank.
    The WI makes it easier to use a guard ring. You do not need to use one on the outside if you do not want to, just as you do not need a ring on the inside when using a single ring in the outer position.
    The Paul hub can let you use larger rings.
    mtbtires.com
    Oct 2012
    Quote Originally Posted by shiggy View Post
    Does that mean that if you mount the ring inside the spider, you are usually at 47.5, and if you mount it outside the spider, you are usually at 52?
    And can I assume that the Paul allows you to use bigger cranks because they end up further away and don't run into the stays?
    FWIW - I just measured my current bike, and the chainline is about 57mm! (It does line up perfectly front and back) There is a visible gap between the BB and the cranks - I wonder if the guy that built it used a BB that was too wide, and then compensated with spacers in the back?
    Hhhnnnngggg!!!
    Mar 2012
    I get a 54mm chainline when using an Eno Trials freewheel with either a Phil Wood K.I.S.S hub or Paul WORD hub. It lines up perfectly with the outer ring position of my cranks.
    73x122.5 Shimano cartridge bottom bracket with Shimano MT60 Deore cranks (stock setup).
    Reputation: asphaltdude's Avatar
    Yes.
    If you mean chainring, yes ;-)
    Ride more!
  1. What do I have in common with the Titanic?
    By kjlued in forum Beginner's Corner
    Last Post: 08-05-2012, 06:33 PM
  2. Is this common practice?
    By ValhallaGSXR in forum Trek
    Last Post: 10-19-2011, 12:43 PM
  3. Most Common Injury?
    By Cormac in forum Rider Down, injuries and recovery
    Last Post: 08-24-2011, 08:48 AM
  4. XS Endos.... How common?
    By Eastcoaster in forum Knolly
    Last Post: 08-09-2011, 06:01 PM
  5. fox 120 mm fork w/ 52mm offset crown on anthem
    By hakalugis in forum Bike and Frame discussion
    Last Post: 03-31-2011, 03:45 PM
