Results 1 to 28 of 28
Thread: magic ratio
    Feb 2006
    magic ratio
    is this tension fine or too loose? thx
    As long as your chainline is good, you should be fine.
    Feb 2006
    could it get more loose? i only used it for 25 kms. thx
    Reputation: GTscoob's Avatar
    Definitely too loose. Maybe add a tooth to the cog out back if you're wanting an easier gear or a tooth to the ring if you're wanting a harder gear.
    Can you take the chain off the ring/cog with your bare hands? If so then your tension is too loose and the chain might come off on its own when bouncing around.
    Quote Originally Posted by Markleo View Post
    As the chain "stretches", it will probably get more loose. Then at that point, just install a half-link.
    My chain is a tiny bit more loose than yours. No issues with mine, though, even running through some rough stuff. Looks like yours is a roadie, so you won't have issues. Just make sure that chainline is good.
    Feb 2006
    Quote Originally Posted by GTscoob View Post
    if i add an 18t at the back (now its a 17t), it gets too tight. no tension at all. is that better?
    No disrespect to GTScoob, but again, that is not too loose.
    Quote Originally Posted by phsycle View Post
    Eh not wanting to get into a pissing contest but I wouldnt ride a chain that loose. Maybe for pavement or a beach cruiser that would be fine but I wouldnt trust it to stay on the rings riding through east coast gnar. If your chain is this loose you've got an issue with your setup, talking to both of you here.
    Does look like a great candidate for a ghost ring. Grab the 22T or 24T granny ring and see if you can put it between the upper and lower runs of the chain, right in front of the cog, it should tension the chain a little better and look cool.
    Or run that 18T cog and do the Sheldon Brown trick of filing down the dropouts a hair to tension the rear wheel.
    Maybe for pavement or a beach cruiser that would be fine.
    Did you look at his tires?
    Feb 2006
    does this look better?
    Reputation: shiggy's Avatar
    Dec 1998
    magic ratio
    No. It looks worse.
    mtbtires.com
    Feb 2006
    Any suggestions. appart from adding a tensioner
    Reputation: Harry Mackenzie's Avatar
    Get a half link.
    I'd be more comfortable with a little more tension and go with a Gusset Half link.
    Dec 1998
    magic ratio
    ENO rear hub.
    mtbtires.com
    Feb 2006
    Quote Originally Posted by goldenaustin View Post
    Yried it. doesnt work. too much of a fuss to change hub. so it either the first pic 44:17 or the 2nd 42:15
    Curious, but how didn't a half link work? If it doesn't work with your current gear ratio, I'd think you'd be able to fix that with changing front ring or rear cog, but the advantage is that the change will be smaller than sticking with all full links.
    Reputation: J.B. Weld's Avatar
    It seems some here wouldn't have a problem with it but no way would I ride either of those, though the first combo looks better. Guess I'm just a wuss.
    A tensioner may be ugly but so is road rash.
    Feb 2006
    When add halflink the chain qr needs 2-3 mm to close. otherwise the chain is too tight.
    "Ghost Rings' - do they work?
    Play around with this if you dont want a tensioner. Otherwise an ENO hub is your only play. Or a Paul eccentric BB. Or a SS frame.
    Have you tried the 44:15 or 42:17 combos? You look pretty close in the first pic.
    Feb 2006
    No luck with the 42:17 i havent tried 44:15 i worry it would be too hard, although it might work.
    Reputation: andrwplsn's Avatar
    the ghost ring is an interesting concept.
    one chain loop
    Reputation: fishcreek's Avatar
    Use the 18t and file your axle a bit.
    everything sucks but my vacuum cleaner.
    Feb 2006
    Ot looks like 44:15 and halflink works. now i will have to see if i can climb those hills with such a gear
    Moderator Moderator
    Best (to me) option is a Phil Wood adjustable bottom bracket (IMHO the best designed bike product I've seen). Run the ratio you want at the tension you need.
    Feb 2006
    44:15 not bad
    looks much better!
    Dive Bomber
    Reputation: jackspade's Avatar
    Looks great.
    You might check the tension stuffs since maybe it's too tight that can kills the body hub.
    My body hub pawl damage like magic, swap with new body and end up with BB mount tensioner but still silence since I put 'silencer' on the roller pulley.
  1. gear ratio help
    By pascale27 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-30-2012, 12:51 PM
  2. EG ratio and spring
    By iammemares in forum Titus
    Last Post: 12-30-2011, 02:54 PM
  3. Gear Ratio for SS
    By EDizzleVR6 in forum Urban/DJ/Park
    Last Post: 10-08-2011, 06:13 AM
  4. Gear ratio
    By Jwind in forum Utah
    Last Post: 06-09-2011, 01:44 PM
  5. I use to think this was magic
    By MarkHL in forum GPS, HRM and Bike Computer
    Last Post: 01-25-2011, 09:37 PM
