Results 1 to 3 of 3
    JJY
    JJY is offline
    Reputation: JJY's Avatar
    Magic Number For 96 Klein Attitude?
    Just looking to save some time. I have a 1996 Pre Trek Klein Attitude, second gereration with rear facing (micro dropouts). Just wondering if you guys have SS'd one and know if there is a drop-in gear ratio that works w/o a tensioner. Appreciate the help... -John Y.
    one chain loop
    Reputation: fishcreek's Avatar
    Quote Originally Posted by JJY
    measure your chainstay length and use this calculator. i used this program on all of my conversions. the ratios close to the shaded area is your magic ratio, usually i look for the ratio left of the shaded area because the chain tension is tighter on that region. hope it helps.
    everything sucks but my vacuum cleaner.
    tmb
    tmb is offline
    When in doubt- turn left
    My bro has a Pulse II from 97, with those same dropouts, that I switched to ss for him. Ended up 32x15 with a halflink, little snugger than I'd run if it were a dedicated ss frame but doable.
    Hope it helps.
    T
