Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 74
    Sep 2004
    low back pain WHY????
    What am I doing wrong? I do core workouts 3x a week, I got a bike fit (for my road bike), and I stretch and use a foam roller, but I STILL managed to wrench my back this weekend during a race. So bad that I can barely walk and it takes me 5 minutes to get out of bed!
    Am I getting too old for this? I'm 40, and I have friends who I regularly chase on group rides who are in their 50's riding bigger gears than I, so that can't be it!
    Is it bike fit? Might be. I just had a pro fit for my road bike, so that is dialed, and I used that to compare against the competitivecyclist and wrenchscience online fit tools, which puts me pretty much right where I am with ETT and stem length. But those tools aren't really taking into account single speed rigid. Plus, they don't specify handlebar width, so what if you're using a wide set of bars (I'm running 711 width).
    Is it climbing technique? When the going gets steep, I pull up on the bars. I try to stick my butt out b/c somebody somewhere said to do that, but maybe that's bad advice. Should I be trying to be as "tall" as possible, or better to be hunched over the bars?
    Is it poor fitness? Possibly. Been a tough winter here on the East Coast, lots of snow and ice, so lots of indoor trainer time. Plus I'd taken a few weeks off just to recup. Maybe jumping on the SS and riding it like I had been last Fall isn't such a smart idea. Maybe I should give the gearie some love for a while until I get the strength and fitness back?
    Anyone have any advice for me? I'd really like to avoid this happening again (I don't do well with pain, ask my wife )
    Jul 2013
    Don't compare yourself to anyone else, even the guys older then you because everyone is different. I'd say core work three times a week is great but its hard to simulate the core action you get from cranking a tall gear up a long steep hill. I'd say if it's been a slow winter and you haven't had much time on the SS then lack of SS acclimation is probably your biggest problem.
    Also if you push a gear while seated that's going to eat up your power backs endurance much faster then standing in my opinion.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I had been riding my whole life without any back issues, but with a new bike setup they suddenly appeared out of nowhere. I'm 31 years of age so not really an oldie or even middle-aged, but certainly not a young gun either.
    Based on how I felt on bikes before and the new bike, I realized that the saddle was tilted back just a wee bit more. This caused me to slip back and semi-consciously compensate by pulling on the bars. Lowering the saddle nose just a little bit stopped my lower back pains as quickly as they had appeared.
    Another saddle adjustment to look at is the fore-aft position. I'm not a big believer in KOPS, because it doesn't account for certain anatomical differences between individuals. For example if you have a light upper body, you can move the saddle forward (compared to the position you'd achieve with KOPS-adjustment) without putting too much weight on your arms.
    Oct 2011
    What are you doing for your "core workouts"?
    Sep 2004
    Quote Originally Posted by Kawigreen99 View Post
    I was doing this: http://m.bicycling.com/training-nutr...g-fitness/core
    But objected to the crunches and leg lifts, as they put a lot of stress on the back.
    Then moved to this: http://www.amazon.com/gp/aw/d/193403...&robot_redir=1
    Which does less crunches and more planks. But they had some funky exercises like supermans, which really stress the back.
    And for the past two months I've been doing this (I have the book): http://www.foundationtraining.com
    These are ore yoga inspired routines which really emphasize the back muscles. But maybe there are some exercises I need to emphasize more than others, Like bird dogs, reverse bridge, and hip extensions?
    What is your gearing? Maybe try using easier gearing for a month or so, take your time, and slowly build your strength up to speed? Sometimes less is more!
    Oct 2011
    Quote Originally Posted by BmoreKen View Post
    I was doing this: Core Exercises for Cyclists: Cycling Training Tips & Workouts | Bicycling Magazine
    And for the past two months I've been doing this (I have the book): Back Pain Exercises & Back Pain Relief – Foundation Training
    Good call on the situps/crunches. I have a friend who has lower back problems and when I asked what he does for exercises, he said situps. I cringed. Your thought on doing more extension exercises is probably a good idea. Most cyclists would benefit from more posterior chain strength.
    Get you butt in and put yourself into a "hiking" or "walking" position. You might need a shorter stem for this. Putting your rear out is an unnatural human movement; get yourself into a natural hiking position. You'll put down more power and really work the lower back. It might hurt a bit after a big climb, but it'll be a good hurt that makes you stronger each ride. My back is messed up from desk work and SSing is the only thing that keeps the pain down. Sitting is bad, standing is good. If you can find that "hiking" position, you can stand all day.
    Jun 2012
    Forget making your "back" stronger. I have two herniated discs in my lower back, and opt not to have surgery to correct it. I have a really, truly fantastic doctor who works on my back though something loosely called chiropractics. He was one of the first people to inform me that everything about your back is supported by your abs. Planks are the answer. By all means, continue your yoga and flexibility/mobility stuff. But do 90 seconds a day on your toes and elbows, first like you're doing a pushup, then turn and do it on each side (only right foot, right elbow/lower arm) touching the ground then do the other side. 90 seconds each. It will suck. You will hate me. But I have yet to hurt my back on a bike, and 5 years ago, I couldn't ride a bike because of my back.
    Reputation: Flat Ark's Avatar
    Does your back not bother you on your road bike? Sounds like you have your core in order. I'm gonna guess bike fit. If I run a stem that is even 5mm too short for me my lower back will pretty much kill me.
    Sent from my HTC One using Tapatalk
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    I'm similar to you in that I do all I should to prepare myself to not have back pain.
    However, I still get it. Turns out, I've got a degenerating disc in my low back. Acupuncture makes it feel brand new, though, so I do that every other week and it keeps me going.
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    Gimme free stuff
    Reputation: tims5377's Avatar
    Oct 2010
    Stretch the piss out of your hammies, quads, hips, and glutes. Then abs and obliques.
    Aaaaaand stand tall when riding! Imagine standing on the floor, feet shoulder width apart, then bending until your upper body is 45 degrees from horizontal and push the butt out. Then think of pushing downward with the legs hard... You would almost be in deadlift posture = major stress on the back
    P.S. The true SSer's motto: "Do it anyway."
    Misfit DiSSent 29er
    Dawes Deadeye [FOR SALE]
    Reputation: fixgeardan's Avatar
    I delt with this for years. Finaly Figured out it wasn't my back at all but the iliopsoaz. Basicly hip flexors that connect on the bottom to hamstrings and femur at the top to the lower 5 vertebrae . Just about any cardio movment running riding causes them to tighten pulling on the back. I started doing hip flexor stretches daily and most all pain has been gone unless I slack on stretching. Just google hip flexor stretches,or tight
    iliopsoaz and start reading up.Total game changer for me.
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    Excessive "pulling up" on yourpedals whilst climbing can overwear your hip flexors and tighen then up pretty good....lower back compensates, body feels pain.Be sure to do the Captain Morgan stretch.
    Veni Vidi Biki
    I came, I saw, I biked.
    Sep 2004
    Quote Originally Posted by SS Hack View Post
    Good advice, good imagery...
    Quote Originally Posted by tims5377 View Post
    ... and this too. Stand tall. I'm going to hit a local hill with this in mind, and consider handlebar placement - I might need to go shorter.
    Quote Originally Posted by Cotharyus View Post
    I do planks as part of my routine, and I definitely agree they're very important.
    Quote Originally Posted by Flat Ark View Post
    I'm dialed in my road bike, comfy for looooong rides. Not sure exactly how to translate road bike fit to MTB fit. I mean, there's reach from my saddle to the bar, or to the hoods, or to the drops, but I'm more upright on MTB and the bars are much wider (711 vs. 440). Any suggestions?
    Quote Originally Posted by Andrea138 View Post
    This might just be the way it is for me, too. I definitely am glad for the core work that I had been doing, as I'd imagine I'd be in much worse shape if I hadn't been doing anything.
    Quote Originally Posted by fixgeardan View Post
    Good suggestion, I'll look into this. Hamstrings and hip flexors are tight from sitting at computer all day.
    Quote Originally Posted by skankingbiker View Post
    I can't say that I pull up on the pedals much at all, maybe only when fighting for traction. I dont' think I pull up at all when standing. Good suggestion, though.
    Stretching and yoga help me a lot. Maybe mix the ss with geared riding off road?
    Reputation: ser jameson's Avatar
    Jun 2012
    I was going to point this out. That tight hip flexors can couse back pain, and tight hip flexors is a common contraindication to cycling.
    That's it--you'll need to recondition your glutes to get involved in pedaling. Try to feel your glutes working when you are pedaling--not just pedaling from the quads-knees. Follow Hack's form above when standing. Work on planks, stretching--especially hips, and do leg exercises that will reteach you to engage your glutes. Side squats are good ones. I bet when you feel the glutes come on line your back will feel great!
    Oh--make sure your saddle is not too high, that will remove your glutes from the power chain, and possibly start you rocking--which is just crushing your discs side-to-side. Feel your entire leg from the butt to the calf pedaling.
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    Wow, so glad I came across this post. This sounds like exactly what I'm going through.
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    Feb 2010
    Same for me, tight hip flexors. Affects me both running and riding.
    I stand up straight while climbing steep and try to use my body weight to power the pedals and focus on using the least amount of muscles to get up the steeps. This helps a lot for the all day epic rides. Sometimes you have to pull hard on the bars but be sure you keep the back straight and tighten the core. Bad form follows tiredness so stay focused in your races. I have lower back problems as well so focusing on body position is always on my mind no matter what I am doing in life.
    1*14*29*2.1 & 1*1*29*2.4
    I assume it hills hurting your back? Are you a seated climber on the road bike, with higher cadence, and is that suiting your back? If it is just the standing mashing SS style of climbing doing it, all those ideas above will help....personally and I think that everyone is different, I find I really need to get my bars low when out of saddle climbing and pushing hard. the upright position isn't good for me. the only way I can engage the whole of my body, especially my core, and save over straining my back is to really hunch over head low. I certainly can't keep that up forever as that is for peak load climbs. If I am more upright, I tend to have more momentum and don't engage the back as much for that reason. Geared seated riding I can gear down to lessen force on pedal and back of course so can stay seated and more upright.
    If you can put up some figures on your road and mtb setup that could help.
    Gotta pay to play
    Reputation: michaelscott's Avatar
    You either have one or both of the problems below:
    1) Your back is weak. Those "exercises" you eluded to are complete sissy ********. Do these:
    Ab rolls with the evil wheel : https://www.youtube.com/watch?v=YmPxIUt7AEw (doing these on the knees is enough. Of course, if you can do standing one arm rolls then you are quite awesome).
    Leg lifts: https://www.youtube.com/watch?v=wr4-McBOJCg
    You should be doing pull ups. If you are bad ass enough you should be doing L-Sit pull ups. If you can do L-Sit pullups then you shouldn't be having back problems.
    Unless...
    2) You sit on your ass all day in front of the computer.
    As others on this thread eluded to. Your hip flexors are probably all jacked up and tight from sitting all day. Do this to stretch them: https://www.youtube.com/watch?v=vwToKziL5A4
    You also might want to look into getting a stand up desk.
    Aug 2010
    I am new to SS but have been dealing with low back pain for a decade after a college soccer injury. Quads, Hipflexers, and Hamstring stretches in that order. I notice that for me, my back is always the worst towards the end of winter/start of spring when I haven't been as active as usual. Hit the stretches hard and push fluids.
  1. Giant trace is a pain, back pain that is.
    By pruitt1222 in forum Beginner's Corner
    Last Post: 08-23-2013, 09:28 PM
  2. Back pain?
    By swcreates in forum Rider Down, injuries and recovery
    Last Post: 12-21-2012, 01:35 PM
  3. Lower back pain - When to get back on the bike?
    By jboyd122 in forum Rider Down, injuries and recovery
    Last Post: 04-12-2012, 03:08 PM
  4. help back pain++
    By buckshotsktm in forum General Discussion
    Last Post: 07-20-2011, 09:49 AM
  5. back pain :(
    By dioprovede in forum Beginner's Corner
    Last Post: 05-18-2011, 09:04 PM
