Results 1 to 30 of 30
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    loosening crank bolts...
    not a huge deal, since there are still cancers without cures, but I was curious if others have problems with loosening crank bolts.
    I have ENO cranks with pretty generic capless type of crank bolts that loosening every so slightly after short rides and more of course over longer rides. I tighten them down a bit before every ride. I loctited them yet still was able to tighten them after they loosened a bit from a ride.
    might another type of crank bolt be better? are the campagnolo crank bolts longer such that they may hold better? etc..
    what has worked for anybody who may have had to deal with this scenario
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    I recall that xrmattaz really recommended Loctite!
    (just kidding)
    yes sir....I did use loctite...i just used the word in the past tense (ie, "loctited")....hey, I ain't no English major or is there an inside joke regarding xrmattaz that i am missing as it relates to loctite?
    Quote Originally Posted by FoShizzle
    ah....now I see, the old loctite on the lockring.
    i tried some loctite on the crank bolt threads hoping that would help and while it may have helped, it still loosens....is this just part of the game with square taper/ENO?
    Torque it
    Is a torque wrench involve in this?
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    What i found out..
    if the crankarm drive and BB drive interface is messed up then all the pressure to keep the crankarm on the BB is on the bolt. And that is why the crankarm wont stay on. For me i wrecked the crankarm and not the BB. But i contacted the manufacturer and got a killer deal on some new crankarms.
    Steamroller
    Reputation: Mattman's Avatar
    Grease? Torque?
    Is the spindle greased? That will cause square taper cranks to go on a little further each time you torque them and may help them loosen faster too.
    No grease on the spindles or in the arms, torque it to proper spec. Grease is OK on the bolt threads, but you may try some locktite instead.
    Two Wheeled and Too Big
    Waiting to exhale.
    Reputation: SMOKEY's Avatar
    I knew the whole square taper thing was a little fishy. keep it simple my foot!
    Quite possibly the slowest single speeder on earth.
    Now skating 'cause its cheaper.
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    I agree with jrm, if the bolt is coming loose, there is not a problem with the bolt, there is a problem with the interface. The cranks are probably toast
    This has been my experience, over the last twenty plus years wrenching
    Quote Originally Posted by jrm
    Todd............. If you can't be kind, at least have the decency to be vague
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Quote Originally Posted by Mattman
    and blue not red
    King Pin
    Reputation: xrmattaz's Avatar
    Wink Hmmmmm....
    SpinWheeeelzz just emailed me, said he used JB Weld.
    (kidding)
    I've four sets of ENO cranks, all with them hex head bolts, and have not had a single one come loose yet. Hmmmm....definitely NO lube on the spindle. A dab of grease (no Lokckkctite) on the bolts and I just use a four inch Allen wrench.
    I cannot imagine a spindle bolt coming loose......something is certainly amiss. You probably should indeed find the proper torque settings and drag out said wrench.
    the bb and cranks are virtually brand new so i sure hope that is not the case....maybe i should get my 12 year old neighbor to torque it better for me
    i am probably exaggerating....it is not as if it is coming loose but rather after a ride or two i can turn the bolt about 1/4 to 1/2 turn which is not much at all of course but still thought I would ask.The bottom bracket is a steel Phil Wood for what it is worth.
    Loctite is Hella Good
    I also have the Eno Cranks and had this problem for awhile. How I fixed it was to Clean the BB axle with denatured alcohol so that there was no types of oily residue on it. Then i did the same thing with the tapered part of the crank arms. Then i used some Loctite 609 on the BB axle and crank arms. 609 is made for bonding bearings to axles and holding PRESS FIT assemblies together. I put the crank together normally using Loctite on the crank bolts so they don't come loose. Has been working great. The Loctite holds 3000psi in sheer so it gives it just what the crank needs to hold it in place. I was worried alittle bit about being able to get the crank off if I have to but with the nature of square taper as you pull the crank of the diameter gets smaller and the crank should come right off. However that is all theory to this point because i have not tried to get my crank arms off yet. I hope this works for you.
    "It never gets easier, you just go faster." - Greg Lemond
    King Pin
    Wink Ahhhh.....
    I just went out and tightened each of mine another 1/4 to 1/2 turn, even the ENO on the 1X1, which I just installed yesterday and haven't ridden yet!
    I don't think anything is amiss anymore....
    Mar 2005
    happened on 3 of my bikes and each time it was an early warning the the BB bearings were beginning to fail...first the crank bolts began to loosen...eventually it was impossible to keep them tight, then you began to feel a wobble in the crank that got worse...you could even hear the rattle
    "Mr. Britannica"
    Quote Originally Posted by lftripp33
    this should not be necessary.
    Whatever! Just crash it!
    Reputation: Objectionable Material's Avatar
    Sep 2004
    It happened to me twice when my ENO cranks were new. I made sure to clean the BB spindle with degreaser, then clean the inside of the crank interface with degreaser. Let them dry thoroughly, then install them. Make sure you've got some grease on the crank bolt threads. I used a torque wrench -- though I don't remember the torque specs off the top of my head.
    I haven't had a problem since.
    Peter
    If a man talks dirty to a woman, it's sexual harassment. If a woman talks dirty to a man, it's $3.95 per minute.
    Bike Wrench Blog ** Unfortunate Series of Events
    I am on the phone with WI right now to get the correct torque setting.
    Just talked to the owner........seems as if (like most of the time cause I am a dumb blond) I am just being paranoid. I will clean off the spindle and inside of cranks and torque appropriately but will not (and dont need to) worry about turning the bolt the pidly 1/8 turn or less after every other ride or so.
    cheers
    Sep 2004
    cheers
    After I had the problem initially, I checked the cranks before every ride. Once I felt secure that they weren't loosening up, I checked them every 3 rides. Now I check them once per week.
    It doesn't hurt to check them.
    I know this isn't the weight weenie thread, but I also wouldn't suggest using anything but steel bolts for attaching cranks. I know not too many folks use ti bolts for them anymore, but there was a day when they were all the rage.
    Good luck.
    Peter
    Thanks again Peter.
    I am with you on the bolts for sure.....I wouldn't mind a alloy matching color threaded cap at some point but no way am I changing the bolt material.
    cheers
    Cubicle Fugitive
    Reputation: czardonic's Avatar
    cheers
    Just because you're paranoid doesn't mean that potentially damaging play isn't developing between the crank and spindle.
    If the crank is seating itself further onto the spindle, thus causing the looseness, I would be diligent about taking up the slack by re-tourquing the bolt. Neglecting the situation will only make it worse and ultimately ruin the crank arm.
    Quote Originally Posted by xrmattaz
    thanks for that info! just give me about 10 minutes and I can post something else to obsess about I am sure
    jrm
    jrm is offline
    Sure they may be brand new
    But that doenst mean that theyre not to spec or the tolerances are off one or the other. Also, if they are brand new use steel crank bolts and not aluminum.
    you bet....I am sticking with steel bolts for sure. thanks again
    Reputation: MudInMyEars's Avatar
    Apr 2005
    Quote Originally Posted by Objectionable Material
    Peter
    From Barnett's Manual 5th Addition:
    SQUARE-FIT CRANK TORQUES
    Manufacturer Minimum-Maximum Torque
    Campagnolo 285-335in-lbs
    Full Speed Ahead (FSA) 304-347in-lbs
    Race Face 420-480in-lbs
    Shimano 305-390in-lbs
    TruVativ 335-370in-lbs
    Good luck!
    those are Rollercams...
    Reputation: WTB-rider's Avatar
    Both the spindle and cranks are new, most likely the cranks are still setting on the spindle. Keep checking the bolts and the loosening should stop once they've set.
    As others have said, using a torque wrench and tightening to the manufacturer's specs is the way to go when the parts are new.
    as usual, thanks to all for your input
    White Ind indicated 22 ft/lbs which is right within the range of many of the above you provide. I need to pick up a torque wrench tomorrow.
    I've got one around my garage somewhere, give me a call if you'd like to borrow it.
    Jim S.
    cool....thanks Jim!
  1. Greasing bottom bracket spindle?
    By Belfrey in forum Tooltime
    Last Post: 07-24-2005, 11:09 PM
  2. Hope (Mono6ti) Ti rotor bolts?
    By d-dsn in forum Brake Time
    Last Post: 05-27-2005, 08:33 AM
  3. 4 crank questions
    By peteer01 in forum General Discussion
    Last Post: 05-13-2005, 11:12 AM
  4. self extracing versus standard bolts?
    By mountain bike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-09-2004, 09:09 AM
  5. What's the white goop on my bb spindle?
    By Spoiler in forum General Discussion
    Last Post: 02-19-2004, 11:16 AM
