Results 1 to 8 of 8
    Reputation: qtip's Avatar
    long term DIY seatpost shims??
    I recently purchased a post/shim on ebay and found out that the ebay ad was not correct....it said that the post was 26.6 w/ a shim for 27.2...I couldn't fit the post in my KM. I'd like to use the post in my KM, but don't want to damage the frame. I've used aluminum cans in the past, but is there a better, more solid, long term way to shim 0.6mm? I can't find a shim that small.
    What about 0.4mm...I've got a 26.8 dean ti post I'd love to throw in the KM.
    KM takes a 27.2 post.
    Whiskey Tango Foxtrot
    Reputation: eSSq's Avatar
    Good job! qbp has them
    i used a qbp brand shim to fit a 27.2 ti am classic into my 30.9 spec m2 hardtail. that worked fin for a couple three years 'til i bent the am classic and switched to a 27.2 control tech, which is still in use today (by a friend who now has my old bike). so, it's worked out for nine years now.
    WAWE
    The following companies offer seatpost shims. 26.8-27.2mm should be fairly easy to locate... as opposed to 30.0-27.2mm.
    Tamer
    USE
    QBP (Problem Solvers)
    Wheels Manufacturing
    Cane Creek
    thanks Al
    I thought the guy at the LBS was wrong when he said he didn't think they made shims that small.
    Quote Originally Posted by qtip
    Actually, shims that small are hard to find - it's only .4mm, after all. The one I found was also pricey - about $30, I think.
    I've read that soda-can metal is around .2mm thick, so 2 wraps would do the job.
    I was in the same situation last year - I had a 26.8 Tamer post, and a 27.2 frame, but ended up selling the post before I could try it with a shim.
    Jon
    Here's one.
    Check these out. Same distributor as for the White Brothers forks.
    http://www.tamerusa.com/Sizers.htm
    B
    WAWE
    Quote Originally Posted by jw25
    I stand corrected.... that is awfully thin and I can't find one online (in my 2 minute search)... I do have a 25.4 to 26.0 handlebar shim (.6mm) and it is awfully thin.
    If the can is .2mm thick, that would be *one* wrap.... when it encircles the post, it .2mm on each side... equaling .4mm. It might work - just don't plan on adjusting your seatpost regularly.
    highly visible
    Reputation: GlowBoy's Avatar
    Pop can seems to work long-term
    Quote Originally Posted by aosty
    Last year when I built up my KHSS I used a fragment of a Mountain Dew can (what else?) to shim my 26.8 Thudbuster seatpost into the bike's 27.0 seat tube. Rode it hundreds of miles, no problem, never slipped. Took about half a wrap, come to think of it.
    Then in October I built up my KM, which has a 27.2 tube, using the same seatpost. Took most of a wrap to shim it up right, so I think the above post regarding that issue is probably about right. Just passed the 400 mile mark last weekend and it hasn't slipped yet.
  1. Ti seatpost vs. Carbon seatpost
    By psOption3 in forum Weight Weenies
    Last Post: 04-12-2004, 09:00 AM
  2. Carbon seatpost shims
    By hjm in forum Weight Weenies
    Last Post: 04-10-2004, 02:58 AM
  3. 24 Race Report (very long)
    By Carter Taylor in forum Passion
    Last Post: 02-23-2004, 08:10 PM
