Results 1 to 2 of 2
    you go ahead
    Feb 2005
    A little advice please... 32T vs 36T
    So I used one of those programs that ask you for measurements then give you some gear ratios you could use sans tensioner...
    mine gave me a nice 36 x 18 and said it would be slightly loose.
    I was wondering if I should then order the Salsa ring 32T like I was going to or 36T.
    Another reason for ordering 36T would be that then if I got stronger or if I was going to ride in the street, I could switch to the 16 cog in the back. (I only have a 16 and an 18)
    But, then I'd probably have to lengthen the chain to do this and shorten it to use the 18 every time I switched...
    Thanks for any advice
    rustyb
    mudnthebloodnthebeer
    Reputation: quaffimodo's Avatar
    Quote Originally Posted by RustyBearings
    rustyb
    If you anticipate going higher than 2:1 gearing the 36 will be your best option. A good rule of thumb to remember is that two teeth (front or rear) equals half a link of chain, and also that any combinations of chainring and cog with the same number of teeth can be swapped with no chain adjustment: i.e., 36:20 and 34:22.
  1. yo ZEDRO I need some advice
    By edge in forum Downhill - Freeride
    Last Post: 01-02-2005, 10:17 PM
  2. commuter bike advice
    By SS4life in forum Singlespeed
    Last Post: 11-29-2004, 03:00 PM
  3. My First Race-Thanks for the advice!
    By HelenFern40 in forum Women's Lounge
    Last Post: 11-10-2004, 01:49 PM
  4. wheel advice?
    By grundy in forum Singlespeed
    Last Post: 11-01-2004, 04:09 PM
  5. chain ring inquiry - from 32t to 36t?
    By cheapfreerider in forum Downhill - Freeride
    Last Post: 06-20-2004, 01:19 PM
