• 03-17-2013
    BigwheelsRbest
    Which lightweight, quality crankset?
    Planning my dream build - a Ti rigid 29er SS.
    What crankset would you use with a 73mm standard English BB type? Looking at a 32T ring, probably, but could go a tad smaller if necessary.
    Must be reasonably light, good quality and look good...
  • 03-17-2013
    Beatniqwood09
    White Industries
    Just got these. Cant wait to getem on my new build
  • 03-17-2013
    stremf
    Not sure on your budget, but XT or XTR.
  • 03-17-2013
    finch2
    there are a few I'd like to try like WI, Paul, etc but I end up with Middleburn for the heel clearance. All of those have good SS options I think. Really, there are a heap of good standard cranks you can set up too. I am running ST these days...your chainline may weed out some options.
  • 03-17-2013
    BigwheelsRbest
    I'm in the UK and am struggling to find SS specific cranksets with Google. No LBS nearby. Where would you buy that White Industries crankset? Or XTR SS-specific cranksets (I can only find doubles and triples)?
  • 03-17-2013
    AlexCuse
    The XTR's are typically modded for SS use. There are a few threads on the subject in here.
    I really like the e13 singlespeed crank, though heel rub is an issue and the anodizing has rubbed off in the year and a half I've had it. I'm not too concerned about the look though. Their proprietary bottom bracket is kind of a pain but it allows a 30 mm spindle which is nice.
    Sram XX1 looks pretty attractive, especially for the price. The GXP model works with an English threaded BB shell.
  • 03-17-2013
    fastcatfear
    I just placed this Truativ AKA's on my SS. They are budget and hollow type design. The link is to a 170mm crank, but search around, I am sure 175mm is avail.
    They are quit stiff, 104bcd and can be found in bb30 and GXP.
    My BB30 version was 709g with bearings and a 32t ring.
    Fasty
  • 03-18-2013
    BigwheelsRbest
    Fasty
    It's not SS specific though - it's a double and bash
  • 03-18-2013
    Andy R
    Charlie the Bikemonger for White Industries, or else Middleburn.
  • 03-18-2013
    fryed_1
    Ditto on the ENO. I love em.
  • 03-18-2013
    MTB Pharm
    Fasty replied with the AKA because you didn't specify SS specific. The AKA and the other SRAM cranks X7, X9, X0 have the removable spider which you can replace with a spiderless chainring like the MRP Blingring.
    If you are looking for good ol' square taper BB crank options, can't go wrong with WI eno or the middleburn.
    If you want something more modern (carbon, outboard bearings) the XX1 is probably the best option (565gm + 69gm = 634 gm). The WI eno is 702 gm with WI ti BB.
    A X0 crank with a bling ring is 509gm without bb (586gm with bb) http://forums.mtbr.com/singlespeed/s...ml#post9810432
    Check out this thread for ideas http://forums.mtbr.com/singlespeed/p...415883-14.html
  • 03-18-2013
    mtnbikej
    If you want something more modern (carbon, outboard buearings) the XX1 is probably the best option (565gm + 69gm = 634 gm). The WI eno is 702 gm with WI ti BB.
    Actually the AKA became the X.9 crankset.
    The current X.7 cleansers do not have removable spiders.
  • 03-18-2013
    BigwheelsRbest
    Thanks MTB Pharm - really useful links.
  • 03-18-2013
    finch2
    Attachment 782286
    Just got my RS7's. Looking at their site they don't do RS8's anymore, but no biggie, only 25g differnce. These sould be plenty strong rated for DH and jumping. They look nicer than my older RS8's, with polished finish and better lines, but a littel dissapointed with weight, although not a problem for me as I am not a weight weenie. Weighed in as you see, without bolts or lockring at 870g, with 1/8 ring. Just a cheap UN52 BB 123, cost $10. Ti would lower the weight more.
  • 03-18-2013
    rob1035
    The X.7 S1400 crankset does...are there multiple X.7s?
    Nevermind. Yup, 3 different X.7 cranks according to SRAM's website. The S1400 is the only one with a removable spider.
  • 03-18-2013
    wjphillips
    My favorite square taper crank is the cook brothers racing crank. Very sleek and sexy looking cranks (in my opinion). They are a bit heavy, but look super nice.
    If weight is an issue, then the high end SRAM or Shimano (Xt or XTR) are bombproof and beautiful.
  • 03-19-2013
    BigwheelsRbest
    Originally Posted by finch2 View Post
    Attachment 782286
    Those are indeed beautiful, but too heavy in my book. On my SIR9 rigid I'm currently running a cheap (65% off RRP at CRC) RaceFace Deus 32T SS crankset and including the BB that is 770g all in (bash ring removed). Was hoping for something materially lighter than that, but still have something that looks awesome.
    Toying with the idea of using a grinder to take away the granny ring sockets, and a wire brush (paint stripper?) to take off the paint on the RaceFace cranks - could reduce weight somewhat (40/50g???) and make them look a whole lot better... Any thoughts?
  • 03-19-2013
    rynoman03
    I went with the Ride version of what you have above in white.
    Race Face Ride Am Oe Cranks > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop
    Not sure on the weight yet. Those Middleburn's look nice! I wish I would have known about them. I wanted the polished RaceFace Evolves but they are out of stock at JensonUSA.com
    If your going to strip the paint off at least polish them. That would look pretty nice!
  • 03-19-2013
    Andy R
    Aren't they anodised, not painted? In which case paint stripper isn't what you need - caustic soda (sodium hydroxide) will do the job, though you won't save any weight worth bothering about.
  • 03-19-2013
    BigwheelsRbest
    Of course, you are right. It's not paint. What about using a grinder with a wire brush attachment - would that give a "brushed" aluminium-type finish that could look a lot better...?
  • 03-19-2013
    rynoman03
    If you go that route make sure you only run the wire wheel in one direction. Otherwise the effect your going for will look not so good I would think.
  • 03-19-2013
    finch2
    no, don't do that. A wire wheel is too coarse. I think you'll really make them look fugly quickly messing with the finish. At most, try to find a scotch brite pad of some sort. Yes as mentioned I thnk you'll be hard up saving 40g with that and the little granny knobs. Re Middleburn the cranks themselves are about 400g. I can't imagine other conventional crank designs being much less in weight. Possibly the x type middleburns are lighter but I don't know. I like my SLX cranks but don't run them SS.
  • 03-19-2013
    rynoman03
    I'd personally leave them alone I don't think they look that bad and saving a 10th of a lb for that much work no thanks...
  • 03-19-2013
    cm_mtb
    White Industries Eno.
    It's made in the US, has exceptional quality, looks great, and is reasonably light... I quite like mine.
    ENO
  • 03-19-2013
    Flat Again???
    I recently upgraded my Karate Monkey with Race Face Turbine cranks. Really nice.
  • 03-21-2013
    BigwheelsRbest
    You're probably right.
    Best alternative I have so far is the XX1 - 650g including the BB. 170 at bikediscount.de:
    SRAM XX1 Kurbel 1x11-fach 32T QF 168mm GXP
    I have a spare Shimano Hollowtech II XT bottom bracket - SM BB70 - can I use this instead of buying a new one for the XX1? (on a Lynskey Pro29 SL)
    This should drop 120g when compared to the RaceFace Deus set up I currently have. Although that's only a quarter of a pound... :skep:
    170 for 120g - not sure it's worth it...
