Results 1 to 9 of 9
    Reputation: Chain-L's Avatar
    Light Stem for Rigid Singlespeed: strong enough?
    Recently bought a SS with Rigid On One carbon fork and it came with a very light Loaded Xlite stem in 7075 Aluminium with a carbon wrapped 7075 faceplate.
    The stem weighs around 109g. I feel a bit uneasy riding in the mountains with a very light stem pushing a heavy gear with a 700mm bar and really putting some levarage into the bars.
    Should I be concerned and get a stronger stem like a Ritchey Trail at 140g with a large faceplate or a thomson X4, or am I being concerned about something which should be fine?
    www.Chain-L.co.za
    Cannondale Flash Carbon 29er 2
    Cannondale CAAD9 Ultegra
    On One Inbred 29er Rigid SS
    Reputation: AlexCuse's Avatar
    I don't know that you *should* be concerned, but if you are concerned I'd get a beefier stem. An ounce and a half of weight savings is not worth feeling less confident in your ride.
    Yeah I only carry cans cause I'm a weight weenie.
    Been riding carbon stems for a couple years... never broke one.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    I know I've used Thomson X-2's on mountain bikes before, but when I used it on the rigid ss I could definitely feel some flex and so I use an X-4 on the rigid single.
    SPP
    Rigid.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    The stem you have might be just fine for your use.
    However, if it doesn't feel right, it's better to switch to a beefier one.
    I'm 185lbs been running a 103g Kalloy Uno stem on the karate monkey for 2 years. I have cracked a carbon niner hb...the stem problem free.
    1*14*29*2.1 & 1*1*29*2.4
    I've been using a Thompson x2 on my hardtail for years. Only time it broke is when I fell off and also broke 3 ribs. It was just the face plate. Replaced that and still going strong. It probably depends on your weight and style more than anything.
    Jan 2014
    Quote Originally Posted by fryed_1 View Post
    In your experience, do carbon stems give a little more dampening to trail chatter? What carbon stems would you recommend?
    Old thread, but my thought is, regardless of whether the stem is strong enough or not, if you don't trust it, having that thought in the back of your mind may affect your ride. Change it out, clear your mind and have fun on the ride.
  1. Light, strong crankset
    By helidave in forum All Mountain
    Last Post: 12-22-2012, 09:27 AM
  2. Need a Strong Light Stem for AM
    By Trail_Blazer in forum Weight Weenies
    Last Post: 08-09-2012, 07:59 PM
  3. looking for strong/light wheelset
    By jrs67 in forum 29er Bikes
    Last Post: 10-13-2011, 04:06 PM
  4. Best AM light but strong wheels?
    By cesalec in forum Wheels and Tires
    Last Post: 04-27-2011, 05:45 PM
  5. adjustable stem strong enough?
    By DaveGT101 in forum General Discussion
    Last Post: 03-27-2011, 07:21 AM
