Results 1 to 10 of 10
Thread: It's alive...
    DSR
    DSR is offline
    It's alive...
    Ok, after having my SS stolen last night which I won't get into, I finally dug in and built up the new, used (but 100% legit!) ENOd singlespeed. All used parts including the stealth Strong built / Kona geometry frame and the ENO rear wheel. It looks good. Now we just need to see how it rides. Tomorrow will be the maiden voyage. I had a few FWs lying around and I'm afraid the one I threw on is a little rough. That may be a PIA given the process of removing a FW off an ENO. I think Ernesto's instructions involved a case of beer. Anywho, my first bike pic... And tell me if anything looks wrong on the ENO position. I just tightened it... it was late... I was still angry. S
    Reputation: scottms33's Avatar
    looks good
    looks like you have alot of parts around if you can just throw another bike together in that amount of time. is that a TI fork ?? and is that titec bar carbon ??? how about we go find that little punk ass ***** that took your bike and cut his little balls off, that sounds like fun..
    scott
    bitc_h
    whats with the censor.. bitc_h is what i ment
    Reputation: MellowCat's Avatar
    hey...
    that ENO wheel looks familier....
    Hope you find your stolen machine!
    MC
    DSR
    DSR is offline
    Well, not exactly lying around. I had a Surly 1x1 and took most of the parts off of that. Wanted something a little lighter weight and with a hanger so I could switch it over to gears if need be. WIsh it were a ti fork. It's a Kona cro-mo. And the bars are just regular alum Hellbents. Nothing too fancy on it, but it's pretty darn light. Can't wait to get it out. Ride the trails looking for that biatch that took my FS bike. Although my guess is that that guy won't be riding it. He's trying to flip it to someone right now. I've called most shops in Boulder/Denver with the description. May end up in a pawn shop. Makes me sad thinking about it. Anyway, MellowCat, are you the Scott I got the ENO from? If so, thanks again! Out, S
    Reputation: ernesto_from_Wisconsin's Avatar
    Eno...
    Quote Originally Posted by DSR
    Sorry about your stolen rig. Next time, lock your bikes to one another, and then to a solid grounded object...
    Anyway, did you let the ENO / frame set the tension on its own?
    DSR
    DSR is offline
    No, had to use a wrench to rotate it back and get tension. And then I snugged the bolts pretty tight. Is that ok? S
    Yes...
    I'm the Scott you got the ENO from!
    Hated to sell it, just didn't need it anymore.
    Hope you find the jerk that took your SS. If you do, don't call the cops......take care of it yourself.....tie him up in the woods or something, hang raw meat around his neck. Real criminals aren't scared of the police.
    MC
    DSR
    DSR is offline
    I was thinking of some brutal irony like tying him up with the cables and then alternating between bike chain whippings and beatings with a crankarm, spider and ring (no bash guard) still attached. Mountain biker justice! S
    and...
    and fingers through a drivetrain, and locking his neck to a lighpost with a U Lock.
    Yes, what you did, rotating it back, is cool.
  1. Whoo whoo! the AZ forum is alive
    By Srexy in forum Arizona
    Last Post: 07-12-2007, 11:59 AM
  2. Does anyone know if Jericho is alive?
    By estylee in forum Custom Builders & Other Manufacturers
    Last Post: 08-31-2004, 09:31 PM
  3. What ever happened to Arraya?
    By Craig T in forum Wheels and Tires
    Last Post: 04-04-2004, 07:32 PM
  4. Fall longings..... pic test.
    By KRob in forum Passion
    Last Post: 01-28-2004, 12:55 PM
  5. Wanted Dead or Alive.... XTR 180 cranks
    By Shiftless in forum Singlespeed
    Last Post: 01-20-2004, 11:26 AM
