Page 2 of 2 FirstFirst 12
Results 101 to 131 of 131
  1. #101
    EXORCIZE
    Reputation: Ryder1's Avatar
    Quote Originally Posted by mack_turtle View Post
    18" black Jabber, looks good so far!
    Very cool, especially the head badge. Looks like a great frame. Congrats.
    2017 Diamondback Haanjo
    2016 Pivot 429T
    2011 Kona Unit
  2. #102
    Jan 2009
    100mm Reba
    Hadely rear hub with 142x12 axle
    34/21 gear with AB oval
    I was hoping to get some riding in the weekend, but Harvey has other plans.
    Thorn in your Sidewall
    Vassago Jabberwocky
  3. #103
    EXORCIZE
    That turned out nicely. Frame/fork look like they're made for each other.
    2016 Pivot 429T
    2011 Kona Unit
  4. #104
    Reputation: Mighty Matt's Avatar
    You got a photo of the rear seat stay clearance with the wheel/ tire in the frame? I've been looking at getting one but don't like 29+ and don't want to get the frame if the bike looks goofy without a 29+ tire in the frame.
    Ride & Smile
  5. #105
    Jan 2009
    It's a pretty big gap, but this is a 25mm i.d. rim with a 29x2.25 Crossmark on it. I am sure that a bigger tire would look more reasonable and leave lots of room for crd to not get jammed up in the frame.
    Also, I don't plan on looking back at my rear tire much while riding.
    Vassago Jabberwocky
  6. #106
    wanna ride bikes?
    Oct 2013
    Looks good man. I'm curious to hear your impression of the geometry of this frame compared to others you've recently owned.
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
  7. #107
    Jan 2009
    I have owned a lot of bikes that didn't fit me well. The closest thing was my Soma Juice, which is an awesome frame.
    My main reason for buying a Jabber was the longer top tube. I sold a Niner ROS 9 to buy this for exactly this reason. Might get a wet pavement/ gravel ride in tomorrow, but Harvey is pushing rainstorms into Central Texas right now, so I won't get a proper trail ride in for a while.
    Vassago Jabberwocky
  8. #108
    Thanks Man!
    I don't plan on looking back there when riding either but 99% of riding is looking good while you do it.
    MM
    Ride & Smile
  9. #109
    Jan 2009
    (I already posted this onbthe wheels forum.)
    Is the 12mm thru axle that comes with this frame just crappy or is it adjustable somehow? When I thighten it, it only works in the 6 o'clock position. This is sketchy.I have seen the light... Vassago convert-2017-09-01-08.03.20.jpg
    Name:  2017-09-01 21.35.31.jpg
    How do you adjust the angle of the lever?
    Vassago Jabberwocky
  10. #110
    Oct 2016
    Is there no adjustable nut on the other side?
  11. #111
    Jan 2009
    No. Should there be? Each dropout is a single, solid piece of metal. Like this B4037: Right Side, Sliding, Hanger, DT Swiss 12 mm
    Vassago Jabberwocky
  12. #112
    Oct 2016
    Huh. I guess they use different 12x142 dropouts on the Jabb/Verhauen. Mine has a nut that can be adjusted similar to on a fork.
  13. #113
    Jan 2009
    That must be a Fox of Shimano thing because my Rockshox fork does not have such an adjustment.
    Vassago Jabberwocky
  14. #114
    Reputation: ARandomBiker's Avatar
    Aug 2014
    Mine is like yours on the 'nut' side Mack, but the lever end is a little different. On mine, I screw the axle in with the lever 'open' to *almost* tight, then flip the lever closed like a reg QR can, and then I can reposition the lever wherever I want.
    Donít modify the trail to match your skills, modify your skills to match the trails.
  15. #115
    Aug 2014
    I keep looking at the pictures on the bottom, I feel like those threads or the set screw allow for adjustment, somehow.
  16. #116
    Oct 2016
    I guess so. For reference, similar to this:
    So, I just checked my other bikes and they use yet another system that also looks different than yours where the axle is screwed in all the way and then clamped at whatever angle is desired. Sorry I can't help.
  17. #117
    Jan 2009
    I figured it out.
    ARandomBiker, you were on the right track.
    Vassago Jabberwocky
  18. #118
    Dec 2011
    Wink
    My frame is on the way! Teaser shot.
    By the way, I received GREAT service all the way through the process. He even called last night and we talked shop for quite awhile even answering all of my stupid and random questions. Tom had already made the sale, and didn't have to talk to me, but he put up with my crap and offered to help me going forward with my build. Looking forward to building it up this winter!
  19. #119
    Feb 2015
    Someone say we need Vassago pictures in this thread?
    My Jabber with WetCat geometry someone called a death machine earlier.
    That is laughable... it is a rock solid XC machine and has been fantastic fun everywhere I have taken it.
    I have seen the light... Vassago convert-v5.jpgI have seen the light... Vassago convert-v4.jpg
    My VerHauen with FastCat geometry. More relaxed than the Jabber - but it was ultimately let go so I could get Vassago #3.
    The Optimus Ti. I have beaten this bike in ways a hardtail should not be beaten. But it has taken it all in stride. THe more I beat it, the more I have grown to like it.I have seen the light... Vassago convert-v2.jpgI have seen the light... Vassago convert-v1.jpg
    Vassago #4 is in the works...
    Regarding the customer service - a the one story is almost impossible for me to imagine. That is not to say it isn't true, just so far from my experience.
    Vassago is a small shop. Tom is the key Cog to it all working... he also races, supports local races, etc... So he is not always at the office or glued to his email. I know that sucks when you want an immediate response - but if you understand that up front, it helps to understand the fast responses followed up with some slow responses.
    I am not making excuses for them... but kind of throwing out there what I know about them and my experience with them. Hopefully that helps others.
  20. #120
    Feb 2015
    mack_turtle - I went back and looked and see you're the one that mentioned the wetcat frame being a crasher... and you also said you loved your juice... I also own a juice and find them hard to compare. I rode the Juice at SSWC in Japan and it did great with a 100mm fork. I ultimately made the Juice geared and went up to a 120mm and my confidence in the bike has faded. So much so, I have it posted locally for sale.
    Granted, I own 4 hardtails - so losing 1 isn't really a loss, but it is the one to go.
  21. #121
    I am Walt
    Reputation: waltaz's Avatar
    Hi all...just noticing this thread, so Iíll weigh in. Longtime MTBR member, but havenít posted much in recent years. Just got a new Optimus Ti 29+, so totally restoked, and have been getting re-engaged here.
    Some background:
    - Iíve been SSíing since ~2005, on Kona Unit 29ís (cracked two), Niner SIR9ís (cracked three), and two Optimus Tiís (ďfirst genĒ from 2013, and the new OpTi)
    - I do endurance XC riding, including 12/24 hour solo stuff. Also do moderate tech, but no crazy shit. I ride it all on my SS.
    With regard to the original OpTi being a ďdeath trapĒ (or whatever was referenced), Iíve got thousands and thousands of miles on mine, including lots of sketch riding/descending, and never thought that. Yes, itís got a 71-degree HA, but itís a racy, XC geometry, and you just need to be prepared to deal with whatever the terrain presents. NBD; itís riding.
    The new OpTi has true ďtrailĒ geometry, with a 68.5-degree HA and shorter chainstays, and itís stable and fun as fvck. Iíve got a Fox 34 120 mm fork on it, and it can do it all. I actively switch between the three travel positions (open, trail, locked) constantly, depending on what is in front of me.
    My biggest question right now is the wheels and tires, since Iím new to 29+. Given my orientation (endurance XC), Iíve favored lighter tires with less rolling resistance. Iíve used Flow EXís for rims, because I hammer my wheels, and donít want issues (and Iíve broken Arches). On my first OpTi, after a ton of real-world experience and experimenting on the harsh terrain of AZ, I settled on Ikonís front and rear - 2.35 fr/2.20 r, and that proved to be the winning combo for me. On my new 29+ OpTi, I started with WTB Ranger 3.0ís on Flow MK3ís (i29mm), which was pushing it for that width on those rims. So I switched to Rekon 2.6ís, which are comfy, but draggy for my application. I will be going to an Ardent 2.4 in front and an Ikon 2.35 in back on the Flows, for races and long, ďdirt roadieĒ rides, but, and here is where it gets good for the new OpTi, I am building up a true ďplusĒ wheelset with sunRingle Duroc 40ís (i36mm) laced to I9ís, with an SS-specific rear. I plan on starting with the Ranger 3.0ís on that, and will see how it goes. I chose the Rangers over Bonti XR2ís (formerly Chupacabraís) because they perform similarly and are 1/3 the cost.
    Lastly, re Vassago and Tom, Tom bought out the brand, which had gone out of business, back in late-2012/early 2013. He is one guy, who was holding down another job, at the time, while he got Vassago retooled and going. He has since quit that job an is dedicated to Vassago. That said, he is one guy, and, as ARandomBiker said above in this thread, he rides a lot, races, attends races and sets up shop to support Vassago riders and wave the flag. He is very passionate and involved, and also recently got married. Did I also mention that he is one guy? Yes, the website can be wonky and/or out of date, and Tom can be slow to reply sometimes, but you just need to stay with it. ďBut itís a businessĒ, you say, and ďYou canít run a business like thatĒ. Well, whatever; he makes it work. Just be patient, and youíll get great bikes and great support. Make sure to hit him up via e-mail (tament@vassagocycles.com) and Facebook (Tom Vassago), and there is also a Facebook page for the Vassago Legion. And stay on him, as he may miss it or forget about it because...see above, and did I mention heís one guy.
    Jeezus, this got LONG! How bout some pics...Iíll post some next.
    Ride more; post less...
  22. #122
    I am Walt
    New OpTi 29+
  23. #123
    I am Walt
  24. #124
    I am Walt
  25. #125
    I am Walt
    Original OpTi
  26. #126
    I am Walt
  27. #127
    Reputation: JoePAz's Avatar
    May 2012
    My Vassago Verhauen in custom gray.
    Joe
    '12 Santa Cruz Highball 29", '13 Santa Cruz Solo 27.5",Vassago Verhauen SS 29" XC, AM, blah blah blah.. I just ride.
  28. #128
    Mar 2011
    Quote Originally Posted by JoePAz View Post
    Hi Joe, I see also have a Highball. I have mine set up SS (aluminum frame). How'd you compare it handling wise to your Verhauen? Looking for something less XC'ish for my next SS.
  29. #129
    May 2012
    Quote Originally Posted by eonicks View Post
    My highball is carbon and the 2012 model with 120 mm fork. The Verhauen runs a 100 mm fork. I have them setup to both handle the same at least to my feeling. Same tires on both bikes and same cockpit arrangement. Geometry is different, but still feel the same. Verhauen has longer Top tube, but steeper head angle. The differece is in the feel, weight and gears. The highball is geared, but lighter 21.5lbs since it has alot of carbon and high end parts (XX1, XTR, etc). The Verhauen is steel and aluminum and is 24lbs. The Verhauen is smoother and more of a sweet ride. The Highball is fast and fast over distance. I race the verhauen because I am racing singlespeed this year, but the highball is faster.
    As for twichy... I don't find either bike twitchy. Both are very good bikes and confidence inspiring. I can't charge some downhill as fast as I can on my 5" Santa Cruz 5010, but that is due to the lack of rear suspension and lack of dropper post. If I have fast tight bench cut downhill where one wrong turn sends me over the edge I am on my 2 HT bikes without a doubt.
    Joe
  30. #130
    Reputation: Driverfound337's Avatar
    Quote Originally Posted by waltaz View Post
    New OpTi 29+
    I thought I was the only guy who rode that far out on hawes
  31. #131
    I am Walt
    Quote Originally Posted by Driverfound337 View Post
    LOL...weíre calling that ďTRW OutersĒ, and that spiderweb of new trails has been getting a ton of traffic recently. Some fun stuff, and nice way to add some miles.
  1. Convert light battery to USB power?
    By bank5 in forum Lights and Night Riding
    Last Post: 07-09-2016, 09:47 PM
  2. It is vassago
    By asookazian in forum General Discussion
    Last Post: 07-23-2015, 01:35 PM
  3. Replies: 6
    Last Post: 10-05-2012, 11:12 AM
  4. FSA K-Force Light MTB Crankset - Convert to 10sp and pressfit BB?
    By field_c in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2012, 07:20 PM
  5. Vassago Van
    By Cycle64 in forum Arizona
    Last Post: 08-02-2012, 10:16 AM
Members who have read this thread: 144
