Results 1 to 32 of 32
    How wide is too wide of a handlebar for SS?
    Hi guys, newbie to SS here.
    I've just build my 1st SS rigid with a 710mm riser handlebar. Coming from a 780mm low riser, it feels kinda small. Would running a 780mm bar on a rigid SS be too wide or just right?
    I'm 5'6", 90kgs.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Subscribed.
    I'm in a similar bind. I wasn't entirely satisfied with a 660mm bar, but I did have two of them. I taped them together and really clamped the stem down on them. The new bar was a little flexy, but not bad on rigid. The big problem was the "bar" was almost wider than my wingspan. On drops and bumps I'd hit my face on the topcap.
    I need to go with something narrower, but right now anything shorter is too short.
    (I run 660 and I'm happy with it. The answer is the width that you want to ride.)
    Come see me after class
    Dec 2005
    my go-to bike is 700mm low-rise with a 45mm stem. i have a 630mm bar (my narrowest) on another bike and i hate it. don't ask me why i still have it.
    to be honest, i don't know how you ran 780mm bars at 5-6. do you have freakishly long arms?
    Nope, last check with a mirror, I'm not an ape... LOL
    I like the leverage it gives me on the descend. Body movement is so far ok on the bike I guess. But that's on a trail bike.
    Out spokin'
    Dec 1999
    I ran some ProTaper SE (7/8ths) motocross bars on my SS for a while... these were 32" (813mm) but I cut them down to 31" (787mm) which felt great but still kept me from getting between too many trees.
    So I went back to "normal" bar width. Whatever that is.
    --sParty
    disciplesofdirt.org
    Reputation: arphaxhad's Avatar
    how about...
    800 mm? i'm enjoying my new Kore torsion bars on my xxix. Oh, i'm 6'3"
    Dec 2005
    everyone has their own preference. try wide first, then narrow. then cut down your wide bar (if at all) until it feels like it's getting too close to the narrow. down here it's all flat XC riding so lots of people can get away with narrow bars (~600mm). if you live in the hills, the extra leverage will probably come in handy for the stand-and-hammer hills.
    of course, if your home trail is anything like mine, 700mm is already pushing it...
    <3mi of the windiest, tightest singletrack... the trees love to reach out and grab you. total elevation change: 15ft.
    Geared bike sighting.
    EDIT: because I dun spell turrible.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    There's no rules. You use what you like.
    I have an 800mm Blackspire flat bar, shortened about an inch at each end because it felt too big at full length.
    Many use bar ends for more leverage going uphill but that wouldn't be so good for the descents.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    talentless hack
    Reputation: zandr's Avatar
    I ran a Gravity Light 800mm on my (geared) trail bike for awhile and thought I really loved it. My friends made fun of me but I didn't care; my super wide bar and I were destined for each other. I finally realized that riding a 6" FS on XC trails was kind of dumb and switched to a HT 29er with a 640mm bar, and it felt so much better. Over the last year I've realized that a bar that narrow puts strain on my hands from being cocked inwards, so my next bar will be 680mm. I think that's the sweet spot for me.
    Personally, I think super narrow or super wide bars are equally as silly, but use what makes you happiest and ignore the haters.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    There is a simple formula to determine bar length.
    Take your height in inches and subtract your European shoe size from that. The result in inches is the precise bar length you need to run.
    Out spokin'
    Dec 1999
    Quote Originally Posted by CB2
    It works!
    --sParty
    disciplesofdirt.org
    Dec 2005
    Quote Originally Posted by umarth
    it's not my photo or my bike.
    surly inbred
    Reputation: TroutBum's Avatar
    Anything less than 28" makes me queasy. Anything more makes my fingers bleed.
    It's a fine line.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    So which European shoe size do I subtract? On some conversion charts, I wear a 48 while on others, I wear a 49. Oh, and either way, that means a 31"-32" bar for me?? Really???
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    surly inbred
    Quote Originally Posted by Malibu412
    True European shoe size is established by the square root of Pi multiplied by green less your stem length. No, not that stem.
    CB2
    CB2 is offline
    Jam Econo
    Yes, really.
    Don't question the formula.
    On wuss patrol
    Quote Originally Posted by TroutBum
    Someone who doesn't need 3 attached to my post.
    Re: the OP question, run as long a bar as you can and still fit between trees/not hit your chin on the stem. Some SSers around here run 28"-30" bars and 22 tooth rear cogs because they like to climb -- a lot. The leverage from the bars and lower gears work for them.
    I just went from a 600mm to a 800mm both flat bars. I am getting used to the 800mm now. I thought 800mm was going to be way to wide and get cought on everything but I got 2 rides on it and so far it has been good. I still have the option to cut it down if I need to.
    hispanic mechanic
    Reputation: sslos's Avatar
    Wow. I've never heard of this, but it seems pretty right-on to me- 698mm bar is about what I'm wanting to try, since my 660mm bar is a touch narrow for me.
    Neat trick.
    5'11", 43.5 shoe, BTW.
    Los
    Whiskey is my yoga.
    dongerparty.com
    Reputation: ne_dan's Avatar
    5'9", 47 feet = 22" bar damn my big feet.
    But, really I run a 710mm wide bar and don't have any problems around here.
    Quote Originally Posted by alexrex20
    Then I am even more mystified as to why you posted the shot.
    Dec 2005
    the trail is super narrow, super twisty, and the trees are super good at grabbing your handlebars. a super wide bar would not be a superb idea.
    Go with the trend and get the widest bar possible.
    I'm possibly looking at retrofitting one of these on my bike. Turning knob is a bonus.
    CB2
    CB2 is offline
    Jam Econo
    Quote Originally Posted by ne_dan
    You know what they say about big feet...big boots!
    FWIW I totally just made "the formula" up this morning although it's pretty dang close in my case.
    67-41.5=25.5"
    Reputation: amishscum's Avatar
    Nov 2006
    A singlespeeder once asked Abraham Lincoln how wide his handlebars should be. Abe replied, "Wide enough to reach your hands".
    "I like skinny jeans. Sometimes I wear them to the mall to get an Orange Julius." -Chim Chim
    hispanic mechanic
    67-41.5=25.5"
    Dood, I was completely impressed.
    Now I'm even more impressed that you used the rectal extraction process to come up with this.
    Los
    Whiskey is my yoga.
    dongerparty.com
    I do think it is hilarious that the metric works, though my current bar is a tad too wide. Since I had already done my math for the day, I sawed off two inches from one side.
    I've made a huge mistake.
    I got that already. Before I scrolled down and saw your photo. Some things are just bound to be cyclical.
    Out spokin'
    Dec 1999
    Quote Originally Posted by p nut
    Be sure to get the matching saddle.
    --sParty
    disciplesofdirt.org
    Quote Originally Posted by Kaizer
    I'm 5'6", 90kgs.
    45" is too wide IMO
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    So, I'm 71 inches tall, with a size 50 shoe.
    Where's the pipe cutters?
    Sometimes, I question the value of my content.
    Bro
    Bro is offline
    Dec 2010
    Quote Originally Posted by elrancho66
    45" is too wide IMO
    That's what she said.
