Results 1 to 17 of 17
    Reputation: jasper9's Avatar
    Jan 2009
    How to remove this lockring?
    I picked up a pair of 29er wheels recently and can't for the life of me figure out how to get the lockring off to add a spacer. It looked like the parktool BBT-18 would work but it won't go on. You can see in the picture it has 8 slots where i thought this tool would thread into but no love.
    I was told they came off a voodoo dambala. alex rims, no idea who makes the hub.
    Reputation: Hudnut's Avatar
    Apr 2005
    Try a spanner wrench
    offroader
    Dec 2008
    Quote Originally Posted by Hudnut
    Spanner will do it.
    Jan 2009
    doh.. always wondered what those were for. thanks guys.
    Schipperkes are cool.
    Reputation: banks's Avatar
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Holy Land Rider.
    i used
    on mine (bonti race SS)
    i used a pipe wrench and a chian whip
    Dudes, a spanner is a wrench in the UK. So using a wrench wrench ain't exactly right grammer. Even if she is old and don't spell so good. With that said the wrench pictured is probably the right one if the teeth fit that lockring.
    Quote Originally Posted by G-man
    Well, we all know the UK has murdered the english language...
    The teeth don't need to fit the gaps. Only one hook needs to engage as long as the rest is supported and doesn't slip off. That spanner works fine on track lockrings even though it isn't made for them.
    Reputation: icecreamjay's Avatar
    I had a hub like that, I think it was made by formula. I just used needle nose pliers and opened em up enough to engage teeth on opposite sides of the hub. It was a pain in the ass trying to hold the chainwhip in place while holding the pliers and trying to unscrew the ring, but I was able to get the lockring off.
    Ultraglide In Black
    Reputation: charmicarmicat's Avatar
    My Shimano bottom bracket wrench works good enough on mine.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    i had a bontrager wheel with the same lockring, and hand tight was all it ever needed. never loosened up while riding, and if the situation arose, i would've been able to change cogs without tools.
    Reputation: rob.char's Avatar
    It looks similar to a truvativ bottom bracket key pattern. Truvativ bb remover tool?
    Mary ss shenanigans
    SSolo, on your left!
    Quote Originally Posted by rob.char
    X2 on that!
    Get off the couch and ride!
    Linoleum Knife
    Reputation: forkboy's Avatar
    Park's Dura Ace 7700 series bottom bracket lockring removal tool.
    http://parktool.com/products/detail....5&item=BBT%2D7
    default title
    Reputation: j e SS e's Avatar
    If you're desperate...a flat head screwdriver and hammer can do the job.
    _______________
    ____________
    _________
    ______
    ___
    _
    Axles of Evil
    Reputation: SS-Dad's Avatar
    Formula lock ring on a Formula hub. As stated above, a Park HCW5 or a Hozan cog tool will do the trick. So will channel locks, a flat blade screw driver and a mallet, or vice grips, if you really want to f-up the lock ring.
