Results 1 to 14 of 14
    indigosky
    Guest
    How to remove cable stops, etc. on my Karate Monkey
    Ok, so the Monkey is getting a new powder coat. I would like to remove the cable stops and v-brake bosses before the new color, but I am nervous about how to accomplish this. Anybody care to offer some advice besides "Use an angle grinder"?
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    Use an angle grinder.
    Quote Originally Posted by indigosky
    How good looking do you want it to be? If you're looking for a perfect finish, then send it off to any shop that works metal and let them know what you're looking for. It should be fairly cheap to accomplish.
    If you don't care so much what the finish looks like, grind it yourself with an angle grinder until you knock off most of the exposed boss. Another approach to this is a dremel tool with a cutting wheel.
    The thing to consider is that it's a steel bike and any mistakes that you make can be corrected with a welder.
    Ken
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    "Use an angle grinder"?[/QUOTE]
    or a Dremel tool,heck what's the worst that could happen?I would practice on a buddy's frame first.
    I've been inside too long.
    I am the owl
    Reputation: riderx's Avatar
    Dremel tool w/ a cut off wheel and then some hand filing. An angle grinder seems a bit big and risky for the job at hand.
    What color will the monkey be?
    SingleSpeedOutlaw .com
    Riding Bikes and Drinking Beer.
    It's not the size of the tool...
    Quote Originally Posted by riderx
    It's not the size of the tool, but how you use it, right Joe? At least that's what all the people with small grinding tools say.
    Ken
    indigosky
    Guest
    Chrome basecoat, Candy Blue with Pearl Firemist. Drool....
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    Wow!... can't wait to see the pictures from the project.
    I am the owl
    Quote Originally Posted by Ken in KC
    Ken
    Well, ya know I recently got a 29er. Maybe I'm trying to over-compensate with the big wheels...
    Reputation: firefox's Avatar
    Sep 2004
    Aren't they just brazed on?
    (ff)
    Am I getting too bulky?
    Reputation: Bikehigh's Avatar
    It's real easy to overheat the steel in a very localized area, burn it and ruin it's temper, when using an angle grinder. It's not like you're sharpening your mower blades and can just grind the burnt section away. I'd stear clear of that method if you care about your bike. Use slow speed methods if you're doing it yourself.
    I gotta roll, can't stand still, got a flame in my heart, can't get my fill.
    indigosky
    Guest
    Quote Originally Posted by Bikehigh
    I had that feeling. Hacksaw and lots of filing for me. Thanks.
    Reputation: zanq's Avatar
    Dremel tool with a cut off wheel, maybe some grinding wheels for the Dremel and a fine hand file should do the trick!
    An angle grinder will work but it's a big tool to do some fine work. I've heard you can go through a lot of material quickly if you aren't careful.
    giddy up!
    Reputation: donkey's Avatar
    I did the exact same thing to my monkey. I used a dremel cutting wheel for the derailleur hanger and to take off large portions of the stops. I tried to keep it at a low speed, so as to avoid heating it up too much. It didn't seem to get too hot.
    After that I used the grinding wheel to get them down close to the frame. Then I used a combination of a flat file and some sandpaper.
    After a new powdercoat I can't really tell where the braze-ons were.
    Do it.
    B
    www.thepathbikeshop.com
    Reputation: MellowCat's Avatar
    Why not...
    just take them off they way they were put on? I'm about 90% sure the stops are brazed on. You should be able to take them off with a normal torch and Mapp gas just fine(oxy/actl torch would be better, but more likely to cause damage if your not sure how to use it). The finished product should look much nicer than the angle grinder or dremel tool. If the steel heats to a dull red thats about the limit for the heat you would want to apply. I would heat the braze on and not the tubes to be safer. Remember, the Surlys aren't exactly made of thin wimpy tubes.
    MC
  1. Karate Monkey in black and Sexy!
    By vcyclist in forum 29er Bikes
    Last Post: 12-03-2004, 01:21 PM
  2. Things to know before building up a Karate Monkey
    By SpinWheelz in forum 29er Bikes
    Last Post: 11-05-2004, 03:34 PM
  3. For fun: Dirt Rag's Monkey review
    By ncj01 in forum 29er Bikes
    Last Post: 04-27-2004, 10:38 AM
  4. S&S coupled karate monkey?
    By jh_on_the_cape in forum 29er Bikes
    Last Post: 03-02-2004, 06:00 PM
  5. Karate Monkey frame questions...
    By KavuBiker in forum Singlespeed
    Last Post: 02-20-2004, 11:39 AM
