Results 1 to 11 of 11
Thread: How Fat a Tire
    Reputation: Mighty Matt's Avatar
    How Fat a Tire
    How fat a tire can I fit on my Bianchi MUSS?
    I was looking at a Race King 2.2 and it looks like it would be cutting it close.
    Pictures to if you have fat tires on one, I like pictures.
    Ride & Smile
    openwound
    Reputation: voodoochild's Avatar
    These are of a 2.3 nevegal on my S.I.S.S. I'm having a 650b rear wheel built and will be running the same tire in a 650b. I'll post up once I get that on the bike.
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    Quote Originally Posted by voodoochild
    you should probably replace your chain soon
    "If women don't find handsome , they should at least find you handy."-Red Green
    sweet. RK 2.2's a go
    Ride & Smile
    Reputation: SeaBass_'s Avatar
    Quote Originally Posted by nuck_chorris
    That's the new Root Beer Brown chain from Niner!
    openwound
    It's actually a coating of trail dust... I thought all of the cool kids didn't wash their bikes?
    Any problems with frame flex causing the tire to rub on the chainstay?
    openwound
    Nope. Though that gap isn't very large, it seems like that would be a lot of flex to get contact. I'm certainly not huge enough to cause that much flex.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    No, that is true.
    openwound
    Quote Originally Posted by umarth
    No, that is true.
    ouch.
    Retro Grouch
    Reputation: aka brad's Avatar
    Quote Originally Posted by Mighty Matt
    Tire fit tends to be tire specific, depending how far the side knobs extend beyond the side of the tire. I have a SASS that came stock with a 2.4 MutanoRaptor, I switched the wheels to 650b (front and back) using 2.3 Nevegals as voodoochild is planning with no problems. Your pictures show you have plenty of room for a wider tire. One hint is to make sure your wheel is centered in the stays. Pictures can be deceiving but if your wheel is off center by just a 1 millimeters it can be a problem.
    Just one more rep and I get the toaster!
