Results 1 to 11 of 11
    Dec 2012
    How do I make my Raleigh a singlespeed?
    Hi, after riding hardpacked snowmobile trails all winter I realized I was carrying around a lot of weight that I didnt need. (5.5 lb fork and a 3x8 drivetrain) Of course on smooth snowmobile trails you really dont need a fork, or gears for that matter. So I would like to make my 2002 Raleigh M60 a single speed (if possible) for next winter.
    I would like to make it a belt drive but have no idea if that would be possible. I'm also fine with the traditional chain drive.
    And also if there are any good kits out there let me know.
    First read Single Speed FAQ Then continue to search either here or Google. So much info on the net about this. I think even some YouTube vids.
    Lastly, forget belt drive. Expensive and you need to cut the frame.
    Jan 2009
    it looks like your rear hub should have a cassette/ freehub interface, instead of a freewheel. this makes things easier.
    1. buy a single-speed cog and spacers and a derailleur hanger-mounted tensioner. 16-18t sized cogs should work just fine. also get a single-speed specific chainring with some short chainring bolts, or just wrap the chain around the middle ring and don't use the other rings. if you chain is worn out, get a new one. otherwise, you can use your old chain and just shorten it.
    2. remove your derailleurs, shifters, cables, and cassette. replace the cassette with the SS cog and use the spacers to get it to line up with the middle chainring. wrap the chain around the front ring and the cog and break off the excess links with a chain tool. re-attach the chain with a proper master link or master pin. install the chain tensioner on the derailleur hanger.
    3. ride and smile.
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    Quote Originally Posted by WillT19 View Post
    Contrary to popular belief, you actually do need a fork and gear(s). You can use a rigid fork if you want, but that's still a fork, and even if you have just one gear ratio, that's still a gear.
    Traditional chain drive has worked for years and years and years. There's no need to change that. And converting to singlespeed is easy. Just take off the stuff that you don't need, and go ride!
    Sometimes, I question the value of my content.
    Dec 2012
    [QUOTE=erik1245;10265597]Contrary to popular belief, you actually do need a fork and gear(s). You can use a rigid fork if you want, but that's still a fork, and even if you have just one gear ratio, that's still a gear. QUOTE]
    Bro
    Bro is offline
    Dec 2010
    It's a peeve of mine. Y'know. Precision of language and whatnot. I'll apologize if you want me to, but I won't be sorry.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    To make your bike a SS......just don't shift.
    Sorry.....someone had to say it.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Quote Originally Posted by erik1245 View Post
    This is awesome.
    one chain loop
    Reputation: fishcreek's Avatar
    Keep the suspension fork. Rigid fork + alu frame = teeth chattering
    everything sucks but my vacuum cleaner.
    Plan #123-D
    Reputation: The_Aaron's Avatar
    And a little "please" and "thank you" will get you pretty far in this forum. Try it.
    C'mon lets go for a whirl.
    Belt drive is not really viable option to retrofit on an aluminum frame. You need to have an open joint somewhere in the rear triangle to allow the belt to loop through the frame. Not terribly hard to braze and retrofit a opening into a steel frame but not a good idea to try with aluminum.
    Post a good picture of the rear-dropout, that will help to better determine how to achieve chain tension adjustment.
  1. New from Raleigh
    By CS2 in forum Internal Gear Hubs
    Last Post: 07-09-2013, 11:50 PM
  2. Raleigh NC
    By jsalvaggio in forum Singlespeed
    Last Post: 11-09-2012, 01:50 PM
  3. Raleigh NC
    By jsalvaggio in forum 29er Bikes
    Last Post: 11-09-2012, 01:02 PM
  4. Replies: 41
    Last Post: 09-27-2012, 08:56 AM
  5. Does anyone make a cross make matchmaker?
    By Andrewfuzzy in forum Brake Time
    Last Post: 06-18-2012, 11:39 AM
