Results 1 to 6 of 6
    Horizontal dropout & rim brake adjustment - problem?
    Do rim brakes require re-adjusting every time you remove the wheel with horizontal dropouts? Should I be looking for rim brakes that are easy to 'tweek'??
    Contrarian
    Reputation: AndyArmstrong's Avatar
    Only if you're taking up a load of slack in the chain and even then not always. I don't think I've ever had to adjust mine.
    Quote Originally Posted by AndyArmstrong
    What brakes do you run out of interest Andy?
    Contrarian
    Mainly Avids of one type or another - I think I've got just about every V brake they make on different bikes. I've got a Single Digit Ultimate on my main V braked / horizontal dropout singlespeed.
    voodoo child
    Reputation: pauly's Avatar
    depends more on the dropouts than the brakes
    The closer your dropouts are to perpindicular to the seat stays, the less fartin' around you'll have to do with the brakes. Old school dropouts and angled track ends (ala older Rick Hunter frames) are good. Traditional track-ends that are close to parallel with the ground tend to be a little problematic, but not too bad.
    highly visible
    Reputation: GlowBoy's Avatar
    Quote Originally Posted by pauly
    Yep. My 'crosser has the angled horizontals, and I can move the axle back and forth across the entire range of the dropouts (1/2") and not have to readjust the brakes.
  1. Please help me diagnose my brake problem -Avids
    By litespeedchick in forum Brake Time
    Last Post: 01-20-2004, 12:17 PM
