    Reputation: noosa2's Avatar
    Hollowtech II and 2006 Monocog flight
    Looks like I will to getting a set of used shimano XT hollowtech II cranks and bottom bracket to put on my 2006 monocog flight frame. The cranks/BB have 3 spacers and I am wondering how many of those I need to use and which side they need to go on.
    Thanks for the help.
    Reputation: plume's Avatar
    if you have a 68 mm BB shell you'll put two spacers on the drive side, one on the non. if you have a 73mm shell it's one on each side.
    My one says BRAP!
    Quote Originally Posted by plume
    Thanks.
    Reputation: kosayno's Avatar
    correct on the 68mm, but with 73mm you only need one on drive side and none on non-drive side.
