Results 1 to 10 of 10
Thread: hey
    May 2005
    Caution;  Merge;  Workers Ahead! hey
    Hey guys I was just wondering if you could have two rings with a derailleur in the front a one in the back?
    Is this possible or would the chain line be all off? Pics of any one who has done this mod.
    Thanks and happy trails
    Cracker-magnon
    Reputation: gpsser's Avatar
    unless you use a tensioner like the Melvin or an old derailleur in the back, I think you would have crazy chain tension problems
    "Life is a F@#^ing story problem, get used to it - my son.
    King Pin
    Reputation: xrmattaz's Avatar
    Caution;  Merge;  Workers Ahead! blasphemy.
    I've not seen, but have heard about some guys and gals running like THREE chainrings in the front, and something like nine or TEN cogs out back!!
    Why? Seems overly complicated to me......
    The man who fell to earth
    Reputation: Ziggy-Stardust's Avatar
    You can do it, but you'll need a derailleur in the rear as well. Another option that avoids front and rear derailleurs is to have two cogs in the back that are perfectly aligned with two respective front rings. Then you can manually derail/rail the chain onto the two ratios as desired (obviously while not on the fly).
    Why not build a wheel around a Shimano Nexus hub, or better yet get an old Sturmey Archer
    Reputation: shiggy's Avatar
    Dec 1998
    Would still need front and rear derailleurs. Would be easier use a single ring up front and 2-3 cogs on the back. Only a rear needed then.
    mtbtires.com
    my 2x1
    Quote Originally Posted by yetirider1989
    I like the two chain ring up frt idea. I've been riding this way for several years. Lately I run a 54 and a 36x16 combo. I can cruise fast to work and climb just about any hill in low range. I still have the benefit of a dishless rear wheel. I like cheap $5 friction shifters, it doesn't even matter if its a left or right shifter. I use a right shifter just to be weird.
    I used to ride off rd with a 36 and a 22 ring up frt and a 20 t fw in back. the 22x20 is hard on the drive train but works fine. I have a much better solution now. I use two gears in back and two up frt. with just a rear der.
    My Surly is a 3x3 now. Now shifter, no derrailleur. My chain length stays the same, no issues. I have a 36x14 high gear, a 32x18 mid range and a weenie 24x28 low range. I shift with a 15 mm wrench on my handlebars.
    My next project is to weld my freehub body so I can have a 3x3 off road fixie.
    my 2x2
    Quote Originally Posted by lef-t
    My 2x2 is working very well.
    surly 3x3
    Another good idea, no derrailleurs, no shifter. Three gears for any terrain. Cheap and no issue. I just did a tough ride and I was happy to have the weenie gear. One chain length works for all three gears. Weld the freehub and you have a fun 3 speed fixie. The shifter will out last all others shimono makes.
    Reputation: Johnny Chicken Bones's Avatar
    Of friggin course it would be possible. Chain line be damned that kinda crap can happen. I mean if we landed on the moon (or so the gov claims) then you can use 2 rings up front.
    course you could go the easy way and use the cool though expensive Schlumpf internal 2 speed bottom bracket crankset. Looks like 1speed but has 2 gear ratios. Perhaps the best of both worlds, perhaps to some the antichrist of one speeding. In the words of GW Bush, Our Freedoms Need Limits! Did he mean shifting?
    --------- __o
    ------- _`\<,_
    Running is for prey.
  1. Hey MTBmoose
    By I Like Bikes in forum Washington
    Last Post: 04-03-2005, 02:23 PM
  2. Hey, hey, hey, Maah Daah Hey!
    By Lucky in forum Passion
    Last Post: 09-21-2004, 03:58 PM
