Results 1 to 14 of 14
    Reputation: lamp no 3's Avatar
    help a fellow soon to be singlespeeder
    I plan on going singlespeed soon enough on my 08 GT Avalanche 3.0 disc but I was wondering, If I go single speed, do I have to run a chain tensioner or can I run the bike without a chain tensioner real clean looking, you know?
    also, what do I do with my cranks?
    26'er GT Avalanche 3.0 Disc singlespeed oh yeah...
    Why is adjusting derailleurs like rocket science to me?
    Reputation: Timon's Avatar
    take the granny & big ring off, and the middle should still work fine as far as the cranks go. may need to get some shorter chainring bolts though.
    it is possible to find a 'magic gear'....aka a cog/chain ring combo that fits snuggly (tensions itself perfectly) when you have a new chain. you'll probably need a half-link, and a couple different sized cogs/chain rings to swap back and forth until you find a combination that works...and then you'll more or less be stuck with that. and you may end up buying new chains more often (under $10 for a pc-1, not too big of a deal)....because the chain wear will make the chain look droopy. (functionally it'll be fine...but atheistically it may look funky)
    the other option is to buy an eccentric rear hub ($130)
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Use bmx chainring bolts. They are the right size for one chain ring , 5 mm as I recall .
    nothing to see here
    Reputation: Stevob's Avatar
    I have an '05 or '06 (I think) GT Avalanche 1.0 converted to single speed, running a magic gear of 33:16, with a half link, and dedicated ss cog at the rear. The new chain has a little slop, but it hasn't caused me any problems yet, and I do give the bike hell. I would think that 34:17 would be perfect, as this should eliminate the need for the half link.
    But that's assuming that the '08 has the same length chainstay as the '06 (42.00cm), which I think it does.
    I see hills.
    I want to climb them.
    bikexor
    Reputation: derockus's Avatar
    Quote Originally Posted by nomit
    I've found you can usually luck out and use the little washers that space the chainrings to fill the gap when you need shorter chainring bolts. Saves a trip to the LBS and a couple bucks. If they don't have washers or they're the wrong size, just get some washers at a hardware store, no biggie.
    Little Shred Riding Hood
    Reputation: traffic002's Avatar
    Dec 2008
    Quote Originally Posted by Stevob
    Can you explain how a half link works? I'm having difficulty picturing this.
    My friend and I both have old HT that seems like it'd be perfect for converting SS for the local trails.
    Quote Originally Posted by traffic002
    Dec 2008
    Bravo!
    Thanks.
    one chain loop
    Reputation: fishcreek's Avatar
    fig.2 is wrong
    everything sucks but my vacuum cleaner.
    Quote Originally Posted by fishcreek
    fig.2 is wrong
    explain?
    Dec 2008
    fig.2 is wrong
    I get it. A "link" consists of one narrow section and one wide section. The half link joins a narrow section to a wide section using only "one" section rather than "two".
    Reputation: ernesto_from_Wisconsin's Avatar
    explain?
    it should go to 11 and it doesn't
    one chain loop
    A+
    got it right
    I'm with stupid
    Reputation: hitechredneck's Avatar
    As a matter of fact i have "said" bike that i turned into a SS last week. I got it from a guy for a good price. Decided that a SS would be fun to build up with parts i had laying around to see if i liked it. So i got this bike 3.0 and trew away the kendas and put on some 2.0 maxis larsons. used a old set of firefex cranks. pulled the granny and big ring and put on bash guard. pulled stock breaks and put on some shimano hydros i had from a take off bike. and the forte SS conversion from perfomance and ditched the stock saddle for a forte carbon one. Into the bike for a total of about 200 bucks. so far having fun, and seeing if i want to stick with this SS thing. Just to warn you with stock fork, wheels, tubes, bars, seat post, and stem, this is a pretty heavy bike. mine came in a around 28 lbs. but i imagine that you could shave weight pretty quick if you changed some things out.
