Results 1 to 11 of 11
    Hayes Hydraulics on my monocog
    Well I swaped out the stock V brakes for a set of Hayes Hydraulics that I had on my Specialized Enduro Pro last night. The stock brakes were ok but nothing like the Hayes. And since drinking the coolaid this season I have not taken the full susp out at all and don't plan on it. I'm a very bad mechanic, however, the installation on the front was no problem. The rear gave me some difficulty and there is still a little drag. The true test will be tonight when I take it out on the trails. I'm praying for nothing catastrophic.
    Keep the rubber side down.
    Todd
    Out spokin'
    Dec 1999
    It's spelled Maunaucaug.
    --Sparty
    disciplesofdirt.org
    Making fat cool since '71
    Reputation: ImaKlyde's Avatar
    Sep 2004
    Warn a fella SpartyCuss...warn a fella. The laptawp will only take so much cahwfy on/in it.
    Brock...
    Are the wheels roundish? Ride it.
    Disciples Of Dirt, come ride with us.
    Moderator Moderator
    Reputation: driver bob's Avatar
    ... and if we just ...
    --Sparty
    Tough brake for the OP but I lmfao.
    What in the world are you guys talking about? I'm lost!
    Moderator Moderator
    Google "hydrolic"
    LOL! Now I get it!
    There I corrected the spelling! Although it was entertaining trying to figure out what you guys were talking about.
    wheelmanron
    As long as the rotor is straight, loosen the bolts for the caliper, squeeze and hold the brake lever, tighten the bolts slowly, a little at a time, first one than the other, until the bolts are torqued properly, and that "should" center the caliper. Seems to work 7 out of 10 times first try. Good luck.
    Come see me after class
    Dec 2005
    it could also be the wheel that's not centered.
    Reputation: blsuedeshu's Avatar
    Mar 2005
    I did the exact same thing on my Flight 29; took the Hayes FX9 Carbons off my Ellswoth that I didn't ride anymore. They work fine. If you did not put in in new pads, remove the pads and make sure the pistons are retracted all the way (may take a few tries) and re-center the calipers.
    Nobody will hurt you more than yourself
