Results 1 to 6 of 6
    Gusset SS Conversion Kit
    Do these work well? I'm considering putting Crossmax XL's on my SS and was going to use this conversion kit. Pros/Cons ???
    Cracker-magnon
    Reputation: gpsser's Avatar
    Quote Originally Posted by zaskar
    Depends. If your wheels have a softer (ti or alum) cassette body, then no, since the cogs are of the narrow shimano/novatech variety. The chainline can be limited as well. For me with the XT wheels that I used it worked perfectly.
    "Life is a F@#^ing story problem, get used to it - my son.
    i worship Mr T
    Reputation: *rt*'s Avatar
    i'm using it on an LX wheelset & it works perfectly. i had no problem at all setting up the chainline and it came with 16 & 18 tooth cogs. i've heard that others have had trouble setting up their chainline because there isn't as much adjustability as if you just used spacers, but, like i said, i didn't have that problem. i did, however have to find a spacer to make it fit snugly. for some reason the cups were about a mm too short for the carrier.
    rt
    "where are you not going so fast?" (question asked to cyclist on a trainer)
    *rt*'s fabulous blog
    mm blogging
    Category Winner
    Reputation: teamdicky's Avatar
    XL's have a steel carrier.
    I use them. The only real issue would be lack of adjustability compared to regular spacers. I stuck with the common variety.
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
    Reputation: GarryB's Avatar
    Spot One Shot Spacer kit
    Try the Spot One Shot spacer kit. I use one on SS with Bontrager Race wheelset. It works great it has different sized spacers that allow fine tuning of the chainline. Looks much cleaner than the spacers taken from a cassette.
    http://www.webcyclery.com/product.ph...cat=402&page=1
    GBB
    Cold. Blue. Steel.
    Reputation: OneGearGuy's Avatar
    What he said... :D
    Quote Originally Posted by gpsser
    i also have an XT disc hub and use the kit with great success. i have TruVative Stylo 180mm cranks and BB and have no trouble getting proper alignment. that and using non ramped rings and cogs is a huge help. plus, the cog is wearing really well and i have been going through chains here in the mountains...
    Spinning and Grinning...
  1. king hub ss conversion
    By Joe_Jitsu in forum Singlespeed
    Last Post: 12-22-2004, 05:02 PM
  2. Soulcraft conversion kit skinny
    By TwistedCrank in forum Singlespeed
    Last Post: 10-26-2004, 11:12 AM
  3. gusset 1'er or wheels manf. conversion kits???
    By biss-ness in forum Singlespeed
    Last Post: 08-26-2004, 10:13 AM
  4. SS conversion complete
    By single track mind in forum Singlespeed
    Last Post: 07-01-2004, 12:47 PM
  5. Anyone using Gusset SS converting kit?
    By piercebrew in forum Singlespeed
    Last Post: 03-26-2004, 11:17 PM
