Results 1 to 15 of 15
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Gusset S-link half link
    I've had no luck using normal 1/2 links, so when I saw the Gusset S-link half link I thought I'd give it a try.
    http://www.universalcycles.com/shopp...s.php?id=22297
    The way it's already assembled and can be installed with just a couple of power links appealed to me.
    At first I couldn't get it installed with new power links, but after I switched to some pre-used ones, it went together fine. So, apparently the 3/32nd version is a little thicker than a 9spd chain. I blame it on the nickel plating.
    The photo below shows what it looks like installed. Hopefully it'll last as long as the chain. Does anyone have additional feedback on the S-link to share?
    Attached Thumbnails Attached Thumbnails Gusset S-link half link-img_5780.jpg
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    surly inbred
    Reputation: TroutBum's Avatar
    Mine have held up nicely using two masterlinks as opposed to Powerlinks... nice to know it's an option. My first go around was the cheap individual half links which broke within hours of installation.
    The Slink is money.
    Out spokin'
    Dec 1999
    Quote Originally Posted by TroutBum
    The Slink is money.
    +1. I use the 3/32" masterlinks that bad mechanic recommended with the slink. It's a great system.
    --sParty
    disciplesofdirt.org
    Mtbr Forum Sponsor - Homebrewed Components
    9 speed chains are not 3/32", which is why a 9 speed power link will not work with it. I also suggest bmx master links, i've broken a few power links, and i'll never use them again.
    Reputation: Andy R's Avatar
    Nov 2008
    It's what I always use (and recommend), with two normal 3/32" masterlinks.
    Since the 9spd power links are working and can be disassembled, I'll go with what I've got until the next time I order parts I put 10+ miles on it yesterday with no noticeable problems.
    surly inbred
    Quote Originally Posted by wv_bob
    FWIW... I refused to pay $8 shipping on a $3 part. As such, I have approximately 17.5432699 years worth of master links & slinks. If anyone wants a trial drop me a line... although you'll be obligated to perform some charitable act... like recommending beer; or respond to every "which ss should I buy" thread.
    surly inbred
    Alrighty... Let's try again.
    Yes, I would like to help a few blokes save a couple bucks. No, I don't wish to give them all away. A nice gesture might be to offer a couple of somethings to cover general graciousness.
    Sorry, my size 9 leather does not taste well this morning.
    ps. if ya just signed up to pm me for free sh|t. ...not happening
    I run a full chain of half links. A bit heavy, but looks pimp.
    I've recently put a KMC 3/8" Half link on my KMC 8sp chain.
    It doesn't seem to run too well at all. Everytime it goes around the rear sprocket (when I'm pedaling, works fine in the stand) I get feedback at the pedals, and an audible clunk.
    Has anyone else got experience with the the KMC half link? Would the Gusset slink be better, or should I try a complete half link chain?
    Cheers.
    Lapierre XR29ei, Chris King LB Carbon, XTR 1 X 10
    Planet X Dirty Harry
    Chiner 29er SS
    Out spokin'
    Dec 1999
    Quote Originally Posted by xcbarny
    Cheers.
    I've used both the KMC POS half link and the Gusset Slink -- the Slink is far better. I've heard half link only chains stretch a lot... and quickly... requiring frequent replacement. They sure look cool, tho.
    --sParty
    disciplesofdirt.org
    surly inbred
    .. Everytime it goes around the rear sprocket (when I'm pedaling, works fine in the stand) I get feedback at the pedals, and an audible clunk.
    Tight link at the new connection?
    I've looked ito that, and I think its ok.
    Noticably, the roller doesn't seem to be as wide as the other rollers on the chain, and seems to have more side to side play.
    Chiner 29er SS
    surly inbred
    Yup, experienced the same. In my case I was in a rush & the kid at the lbs gave me what he thought was a 3/32"...I'm not so sure it was.
    As Sparty mentioned... POS. Go Gusset.
    OK thanks
    I've ordered a slink
    Chiner 29er SS
