Results 1 to 8 of 8
    Boyeeee
    Reputation: BCBlur's Avatar
    Gusset 1-ER and King Cog
    Will the Gusset 1-ER work with a King Cog?
    I noticed that the King Cog is a little thicker than the cogs that come with the Gusset and was wondering if there would be any issues using the two together.
    Everything's going on a Shimano LX cassette if that matters.
    http://www.pricepoint.com/detail.htm...8&hprice=19.98
    Thanks.
    Reputation: mabaGAL's Avatar
    Quote Originally Posted by BCBlur
    Thanks.
    Not without some filing of the spacers.
    Boyeeee
    Quote Originally Posted by mabaGAL
    Any recomendations on a clean looking spacer kit?
    I guess I could always buy two Gusset 1-Er kits, run both small spacers and a spacer from another kit (maybe a standard cassette spacer?).
    SS Grrrrrrrl
    Reputation: dirtcrab's Avatar
    Just buy some standard aluminum cassette spacers... or you can buy nice Ti ones from Boone.
    indigosky
    Guest
    It will work but...
    it will work but you need to file away part of the inside of the spacers to clear the wide base on the king cog. I did it with mine, and on the inside it doesn't look pretty, but when it's installed, it looks great, because you can't see the file marks. good luck.
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    I doubt you'd get much cleaner than going with the PVC pipe idea.
    Just Ride!
    Reputation: kustomz's Avatar
    Check out Spot Brand spacer kit with a Kog.......... Love mine.
    Boyeeee
    That's what I ended up doing. I'll see how everything comes together when all my parts come in.
    Quote Originally Posted by kustomz
