Results 1 to 9 of 9
    Faster Than Your TV!
    Reputation: iconoclaSSt's Avatar
    Bonking ... not feelin' well Good thing it didn't happen at Big Bear...
    Actually, that's probably where it originated. Rear rim. Same on the other side. Guess I better get some finesse...
    "I still feel that variable gears are only for people over forty-five. Isn't it better to triumph by the strength of your muscles than by the artifice of a derailleur? We are getting soft...As for me, give me a fixed gear!'' -- Henri Desgrange, from an article in L'Equipe
    Wrench In the Gears
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by iconoclaSSt
    That has nothing to do with finesse or lack of it.
    The brakes wore through the sidewall. I have had a 6" section of rim blow apart on a downhill because of brake wear.
    mtbtires.com
    Yeah,
    Quote Originally Posted by shiggy
    ...the finesse part was tongue-in-cheek (though it wouldn't hurt to have some!) . Rim is pretty old and I do my share of braking when I ride; I've seen similar cases with other riders where the sidewall actually peeled away.
    How'd you handle it when yours exploded?
    Wrench In the Gears
    had that happen to me once too, the wheel blew apart as I was riding down the street on the way to the trail. The wheel blew apart sufficiently that the tube exploded - I thought it was a gunshot and just about dove for cover. Luckily the noise drew a lady out into her yard, phone in hand - she lent it to me to call a friend for a ride home.
    Dec 1998
    20mph. Straight gravel downhill. Front rim split. Tube blew. Tire stayed on the rim.
    Stayed upright. Stopped without a problem using just the rear brake.
    Happened in the last mile of a 40 mile ride.
    It was the only rim I have had fail though I wore out a rear rim every year and fronts every 2-3 years before I switched to discs.
    mtbtires.com
    Reputation: noslogan's Avatar
    How many miles
    How many miles does a rim have to have on it before that happens? Ive got a set that must have 10,000 miles on it.
    Dec 1998
    Quote Originally Posted by noslogan
    It is not about miles. It is the conditions. I have 10 year old road wheels with many, many thousands of miles on them and almost no brake wear.
    On my mtb I ride year-round, much of it in wet and muddy weather. Not only is there more grit on the rims I tend to use the brakes more.
    It also depends on the specific rim. Some rims have thin sidewalls, others are thicker. Given two rims of the same dimensions the heaver rim will most likely last longer.
    mtbtires.com
    F@CK da dumb
    Reputation: joyride1x1's Avatar
    knackered
    Dude, that rim is knackered. I'm not surprised because that downhill section at Big Bear was a mother. My wrists went numb pulling on the levers so hard.
    Fat Boy Deluxe
    Reputation: DmofoT's Avatar
    Quote Originally Posted by joyride1x1
    Pansy ass...what were you pulling on the brakes for? Guess it didn't hurt your times any though, haha.
    DT
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. No More Dh At Big Bear!!
    By bombergirl in forum California - Socal
    Last Post: 12-12-2004, 11:22 PM
  3. Poaching fallout? (Snow Summit, Big Bear Lake California)
    By BrianU in forum General Discussion
    Last Post: 12-08-2004, 03:03 PM
  4. Bruise Chronicles: Big Bear Race Report
    By sunnyracegirl in forum Passion
    Last Post: 08-01-2004, 04:29 AM
  5. Bruise Chronicles: Big Bear Race Report (X-post)
    By sunnyracegirl in forum Women's Lounge
    Last Post: 07-02-2004, 08:39 AM
