    Ghost Chainring - Fixed Gear Question
    I've got a SS commuter with vertical dropouts and an old deraileur as a tensioner. I'd like to make it a fixed gear. In the FAQs it says you "should be able to" do it with a ghost chainring. Has anyone tried it?
    bon vivant
    check out the picture threads in this forum, I've seen two bikes with ghost rings in the last two weeks.
    Quote Originally Posted by Paul Doe
    I think it depends alot on how much slack you have to get out of the chain and how your chainstays are shaped. I tried to do that on my cannondale, and the ghost ring I needed for tension rubbed on the chainstay so I couldn't do it.
    no gears, no tears
    Reputation: giantrider's Avatar
    Quote Originally Posted by cloughja
    Worked fine on my giant, but i only rode it that way for 3 days. I had about 2mm clearance between the stay and the ghost ring. I have a 15 tooth on now instead of the 14 so i don't need it anymore. I do agree that it probably depends on the shape of your chainstays and how much slack you have to take out. Ask at your lbs if they have any old cogsets layin around, they'll likely give them to you so it won't cost you anything to try it.
  1. want to try fixed gear on my ENO......looking for cog
    By SS'r in Kansas in forum Singlespeed
    Last Post: 04-01-2004, 01:56 PM
  2. ROHLOFF: Chainring question
    By robertange in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-23-2004, 05:17 PM
  3. Calling all fixed gear freaks.....[SPAM]
    By Singlespeedpunk in forum Singlespeed
    Last Post: 02-18-2004, 04:44 AM
  4. disc + freewheel + fixed gear?
    By qtip in forum Singlespeed
    Last Post: 02-13-2004, 08:04 PM
  5. Help me pick a commuter fixed gear...please
    By gabe0807 in forum Singlespeed
    Last Post: 01-31-2004, 03:53 PM
