    Reputation: Harry Mackenzie's Avatar
    Gear ratio question, help satisfy my curiousity.
    Let's say for example you have a 34x18 and you can somehow switch the cog and the chainring around so now you have an 18x34. Does this change anything at all with the force you are applying to the pedals while climbing? It sounds pretty obvious that the answer is no but I'm curious if I'm wrong on that one.
    Mar 2012
    Quote Originally Posted by AnonymouseTech View Post
    Ah woah... What happens if you are riding a geared bike, and to drop into say a 22 tooth chain ring and a 34 tooth cog? Not quite an 18 tooth up front, but it might give you a clue as to how it'll climb...
    Reputation: Face Visor's Avatar
    April fools?
    Just Ride
    Reputation: Cormac's Avatar
    I'd imagine you could climb straight vertical with that gear ratio!
    SS ==> Nut up or Shut up!
  1. Getting old... SS gear ratio question
    By jugdish in forum Colorado - Front Range
    Last Post: 01-26-2013, 06:32 PM
  2. gear ratio help
    By pascale27 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-30-2012, 12:51 PM
  3. Gear ratio question
    By Managuense in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2011, 08:46 PM
  4. 650b ss gear ratio question
    By nyxcracer in forum 27.5
    Last Post: 07-16-2011, 08:51 PM
  5. Gear Ratio Question
    By confusedxx in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2011, 09:07 AM
