Results 1 to 3 of 3
    Dec 2011
    Which gear combination to use?
    Okay, I am going to cheat a little and run a single speed rear drive with a Schlumpf Speed Drive crank that has both 1:1 and 1:1.65 ratios.
    I can get the crank with chainrings ranging from 27-40T.
    What would be the best rear/ front sprocket combination to use given the available chainring sizes and the crank's two ratios for slow, technical trails that would also allow a decent speed on the flats?
    Feb 2007
    I'd start off w/ a 2:1, maybe like 32/16.
    Self Inflicted
    You are for sure gonna want to use the 27 tooth chainring. that equals a 44.5 t ring in overdrive which is huge. plus using a smaller ring in the front keeps the two different ratios as close as possible. The gap between gears gets proportionally larger as the ring size goes up.
    I'd go with a 22 tooth cog. this would give just above 2 to 1 in overdrive plus a nice low gear for techy sections and hills. If you want to go higher use a smaller cog.
  1. WTB tires combination
    By Cryohazard in forum Wheels and Tires
    Last Post: 03-19-2009, 11:30 AM
  2. Best Combination?
    By GBR1 in forum Wheels and Tires
    Last Post: 10-17-2008, 06:40 PM
  3. A bad combination...
    By Walt Dizzy in forum Wheels and Tires
    Last Post: 02-29-2008, 09:37 PM
  4. Is this a right combination?
    By znarf420 in forum Turner
    Last Post: 12-19-2006, 09:07 AM
  5. Replies: 1
    Last Post: 01-15-2006, 10:52 AM
