Results 1 to 12 of 12
    Fully Polished Fox F80RLT - Ouch, My Eyes
    Anybody else have a set of fully polished fox forks? Do I need to clear coat or does the finish hold up? These used to be light grey. I wanted white but figured polished would be the next best thing. I serviced the fork while I was at it. 3cc of float fluid feels so much better than the recommended 5cc. Love this fork!
    Better photos and complete bike pics to come.
    Interlectchewal
    Reputation: tvrbob86's Avatar
    Aug 2005
    That's going to look great on the back of your Audi Avus.
    one chain loop
    Reputation: fishcreek's Avatar
    for me, some bike parts doesn't look good in chrome. fork is one of them.
    everything sucks but my vacuum cleaner.
    Reputation: Treybiker's Avatar
    BLANG BLAAAAAAAAAAANG!!!
    Reputation: Irrenarzt's Avatar
    Did you self polish that?
    Quote Originally Posted by Irrenarzt
    Ya, I polished it myself. I really wanted a newer white F80 or F100 but figured I'd give teh polished look a chance. It looks pretty good on the complete bike. Normally I wouldn't like a polished fork.
    How did you polish it? I just threw a set of brake calipers in a jar of stripper last night so I plan on polishing them tonight. Just wondering how you went about it.
    Thanks in advance.
    Thanks in advance.
    Disassembled the fork and sprayed it down with Aircraft Remover. Once the paint was off I started went sanding with 400, then 1000, then 1500 grit sand paper. Let it all dry and then took a clean rag and some mother's mag polish to it. Polishing took about an hour. Takes about 10-15 to disassemble and reassemble the fork.
    You definitely need some sort of paint on there. Magnesium is really reactive, and will oxidize pretty darn quick, and look gross. Do you remember the Easton mag stems? Yea, that could happen to your fork.
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    Quote Originally Posted by msrothwe
    ditto. but that fork looks geat!
    "forget kings...forget hadleys......they all have crap engagement. just run your bike fixed gear." - FoShizzle
    Reputation: trekbuddy's Avatar
    If you want to keep the polished look you should clear coat it. Otherwise it will lose that look and you will have to polish it again. Same as a magnesium wheel. They all have clear coat on them.
    Don't talk back to Darth Vader or he'll getcha!
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Clear coat.
    Otherwise expect the *bling* to be gone in as little as a week.
