Results 1 to 5 of 5
    Dec 2011
    FreeWheel Durability
    Just got a White Industries Wheel Set and have to switch from free hub to freewheel. Was wondering what a good option is besides the uber White industries freehub? I am also looking for a 22 tooth, so that limits what is available. How long can I expect it to last?
    in general, do regular feww hubs and freewheels have similar number of engagment points or do you sacrifice that with a freewheel unless you get a trials version?
    -Jesse
    Dinner for wolves
    Reputation: buddhak's Avatar
    Go to the tartybikes website and take a look at the WI alternatives in a high engagement FW. They are more reasonably priced than WI, but with unproven track records. The dicta and shimano bottom level FW are cheap but fragile. FWIW, I use a WI Trials, and it has been just flawless for the past 2 years. Shop around for a good price an it will be money+time well spent. Also, spend some time working out your gearing needs on a gear calculator before investing in a FW. It sounds like you already have a crank and chainring limiting your FW choices, however. You may have no choice but to run a non-trials WI.
    Responds to gravity
    Reputation: ancient rascal's Avatar
    + 1 on WI. No problems with my 22t. Put it on and forget about it !
    Suicide by single speed. Work in progress.
    Riding rigid
    Engagement points can vary all across the board. POE is over rated IMHO. While nice, I don't notice the difference between my King SS hubs and my WI freewheel.
    If you want WI with the trials engagement but a 22t, you'll have to buy two the 18t trials and a 22t standard ENO then do a swap. Then sell the 18t as a regular ENO. I've seen the occasional ENO body minus the guts before on fleabay or here.
    Dinner for wolves
    Or call the nice folks at WI and see if they can sell you parts directly.
    Responds to gravity
  1. 355 durability?
    By Chad5080 in forum Wheels and Tires
    Last Post: 10-03-2011, 01:31 PM
  2. Replies: 4
    Last Post: 06-28-2011, 03:13 PM
  3. Single speed freewheel durability question
    By Morlahach in forum Endurance XC Racing
    Last Post: 02-13-2007, 08:27 PM
  4. Eno Durability?
    By BThor in forum Singlespeed
    Last Post: 01-06-2006, 08:18 AM
  5. X0 R/D durability?
    By xjbebop in forum SRAM
    Last Post: 09-05-2005, 12:24 PM
