Results 1 to 3 of 3
    Dec 2012
    Forte Single Speed conversion kit + Raceface singlespeed 9/10 compatible crankset....
    Hey All,
    I recently picked up a Raceface single speed crankset which says its 9/10 speed compatible. (Race Face Ride Single Speed Crankset > Components > Drivetrain > Cranksets | Jenson USA)
    Eventually I want to go 1x10, but for now I want to try singlespeed - I was thinking of getting the "Forte singlespeed conversion kit" but, it says its only compatible with a singlespeed or 8speed chain... (Forté Single-Speed Conversion Kit -)
    With this combination, what chain should I run? I'm hoping to do this on the cheap, in case I end up not liking single speed...
    Would this chain work? Black Single Speed Fixie Bicycle Chain YBN 1 2x1 8" 112 Schwinn Cruiser Bike BMX | eBay
    can you recommend a cheap, black, compatible chain?
    Do I need to worry about a single speed chain/8 speed chaing prematurely wearing out a 9/10 speed compatible chainring?
    Shyam
    Oct 2013
    I've been running a RaceFace Narrow/Wide chainring with a Sram 950 chain and a ACS 8 speed freewheel. I haven't run into any problems myself. I'm more worried about an 8 speed chain messing up the aluminum chainring than a 9 speed chain messing up a steel freewheel. My $.02.
    Also, that is a bmx style chain you have linked to. Buy a Sram 8 or 9 speed.
    SRAM PC-971 9SP Chain > Components > Drivetrain > Chains | Jenson USA It isn't black, but that should be your least concern on dialing in your drivetrain.
    Dec 2012
  1. Single Speed Crankset
    By Nic Chavez in forum 29er Bikes
    Last Post: 06-10-2014, 05:45 PM
  2. Is this crankset 10 speed compatible?
    By jarango in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2013, 08:27 AM
  3. New 9- 8- speed Crankset compatible with 7- speed cassete??
    By GiantRev2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2012, 07:32 PM
  4. 29er Frames: Single Speed & Gear Compatible
    By S.O.B. in forum Singlespeed
    Last Post: 01-24-2012, 11:00 AM
  5. TruvatIv Noir crankset + Raceface 10 speed rings
    By CasinoKiD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2011, 11:10 PM
