Results 1 to 7 of 7
    formula dc52n ss hub. what lockring and axle nuts?
    i bought a wheel dirt cheap with this hub on it, seems to be in good shape but it came sans the cog, lockring and axle nuts. i know the cog is a regular shimano spline so thats not an issue, i just want to make sure i get the right lockring and nuts. anyone know?
    Reputation: asphaltdude's Avatar
    Nuts are ordinary M10.
    Not sure where to get the lock ring (though I own one of these hubs....)
    Ride more!
    thanks, that helps. googling i found that formula track hubs used dura-ace designs with m9 front nuts and m10 rear, but i wasn't sure it related to this kind of hub. now i just have to pin point the lockring.
    Axle nuts depends on if it is quick release or nutted.
    I believe the lockring is usually the same thread as a BSA bottom bracket. Your LBS or co-op should have all kinds of those in junk drawers.
    it is a nutted hub of course, i have QR skewers kicking around so that wouldn't have been a problem. i happen to have had an old BB in my parts bin so i tried out the lockring, sure enough it fit. nice to see them use a standard of sorts, thanks for the tip. my LBS managed to scrounge a few m10 nuts so i am set.
    thanks again.
    Have you tried the nuts?
    From the Park site:
    Basic Thread Concepts | Park Tool
    3/8 inch x 26 tpi Solid rear axle
    10mm x 1mm Most quick release rear axles, derailleur mounting bolts, brake lever adjusting barrels
    10mm x 26 tpi Rear axle, quick release, CampganoloŽ
    sorry, missed this. yes i did, i brought the wheel to my LBS and made sure they fit. i actually didn't confirm whether they were m10x1 or m10x26, but they found the right ones. online searching indicated they would be m10x1 and the nuts look exactly the same as old dura-ace nuts(chrome with a floating washer) which it seems formula decided to use with their hubs.
  1. Replacement for a formula xqr-12e 12x142 thru axle
    By btablak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-24-2016, 07:16 PM
  2. Formula QR rear hub axle upgrade?
    By pigmode in forum Singlespeed
    Last Post: 12-23-2013, 12:45 PM
  3. Replies: 2
    Last Post: 03-24-2013, 12:37 PM
  4. 15mm qr axle in Formula DC20?
    By Muffinhead in forum Beginner's Corner
    Last Post: 08-28-2012, 11:39 AM
  5. Finding Shimano axle nuts is driving me.....nuts
    By recumbentguy in forum Wheels and Tires
    Last Post: 03-21-2012, 01:42 PM
