Results 1 to 5 of 5
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    fixing cassette hub?
    hello. I have an old suntour seven speed wheel I would like to fix, mostly for road usage. i will start with front and rear brakes.
    It has a freehub for 7 speed, like I said. The cassette is held on with the smallest cog as a lockring, so if I fix the freehub, I would put on a SS cog, then use that small cog as a lockring (with copious loctite, but doesnt matter, cause it's a fixed spline...).
    Soo... can I do this without taking everything apart? I had thought of just squirting JB weld in there, but I am afraid of seizing the axle, as well. any special hole to squirt in the JB weld?
    My friend has a tig welder. Can I just weld the snot out of it on the outside? again, dont want to sieze the bearings or cook anything else.
    If I have to take it all apart anyway... well, I'll just go riding instead.
    sorry no pics.
    it looks like this, see the threads?
    Only boring people get bored.
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    Caution;  Merge;  Workers Ahead!
    After you "fix" it, where are you going to find a single speed cog to fit on a Suntour freehub body?
    Todd............. If you can't be kind, at least have the decency to be vague
    Quote Originally Posted by 32seventeen
    from the 7 speed cassette. but they have a different spline??
    Quote Originally Posted by jh_on_the_cape
    The seven speed greary cog may not work. I know the shitmano geared cog will NOT hold the chain. If this is on a built wheel, I would put some spacers on there and try it as a SS first. That way you will know if it will work before you spend a bunch of time "fixing" it.
    good call. thanks. I will do this (tomorrow?)
  1. Replies: 18
    Last Post: 08-08-2007, 05:48 AM
  2. Problem fitting cassette to Chris King hub
    By Anders in forum Weight Weenies
    Last Post: 01-06-2005, 01:56 AM
  3. Problem fitting cassette to Chris King hub
    By Anders in forum Wheels and Tires
    Last Post: 12-18-2004, 03:39 PM
  4. little wobble on my cassette on XT hub
    By arlopex in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2004, 11:23 AM
  5. Replies: 20
    Last Post: 03-05-2004, 10:20 PM
