Results 1 to 7 of 7
    Dec 2004
    fixed gear / wheel question
    I know that this is the S.S. forum but itís as close as it gets to a fixed gear. I bought a SPECIALIZED LARSON to train and improve my spin. It came without Q.R. axles, I had the shop swap out the front axle to a Q.R. but they said that the rear needed to remain a bolted axle because of the torque. My question is, there has been many a time when I came up to a surprise hill and found myself in the wrong gear and stood up and mashed the petals, all my other bikes have Q.R. rear axles, and they donít slip. This couldnít create more torque than I would on a fixed gear, why wouldnít a Q.R. on the back work. The reason I want a Q.R. on both axles is for the ease of changing flats. Thanks in advance.
    Medium?
    Reputation: Fast Eddy's Avatar
    Vertical dropouts
    Most modern geary bikes have vertical dropouts, so the torque is transferred directly into the frame, where the axle can't slip. A standard fixie has horizontal or semi-horizontal track ends (not dropouts) to allow chain tensioning.
    That said, my first fixie had semi-horizontal dropouts, and I was able to get away with a strong cro-mo quick release with a serrated washer on the drive side.
    paintbucket
    Reputation: wooglin's Avatar
    I run an old Campy qr on my road fix with no problems, horizontal dropouts and all. SSing on trails seems to create a lot more torque than road riding.
    When the going gets weird its bedtime.
    Excuse to buy a Jethro THule from Surly.
    Better safe than sorry. If it slips you;ll know about it.
    Quote Originally Posted by TomL
    or just a nice long handled 15mm box wrench from sears.
    Dec 2004
    Thanks for the help
    Thanks for the help
    HHL
    HHL is offline
    Que je suis bete!
    QR rear
    I use a Salsa steel QR with no problem on my horizontal forks with no problem. You do have to make sure it is really tight, however. I only weigh 150 but when I'm on a steep hill I will move it if I haven't torqued it down. The Salsas have plastic washers and so far no problem.
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. What about fixed gear?
    By Axe in forum Singlespeed
    Last Post: 05-28-2005, 06:23 PM
  3. My fixed gear Contraption
    By williamf777 in forum Singlespeed
    Last Post: 12-21-2004, 10:28 AM
  4. Question about recent wheel lacing debate.
    By TNC in forum Downhill - Freeride
    Last Post: 04-26-2004, 02:34 PM
  5. disc + freewheel + fixed gear?
    By qtip in forum Singlespeed
    Last Post: 02-13-2004, 08:04 PM
