Results 1 to 12 of 12
    used to be uno-speedo....
    Reputation: dirtdrop's Avatar
    Fixed gear setup questions
    So I have an old frame with vertical drops and want to run it fixed. Here's what I'm thinking. Can I use an ENO eccentric disc hub with a TomiCog?
    Reputation: metrotuned's Avatar
    Sure go for it. What wheel in back are you going to run? Is this going to be a monstercross like your avatar?
    Producer, Actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
    Quote Originally Posted by illnacord
    Uhhh the plan is to go with an ENO eccentric disc hub and probably a Mavic rim of some description.
    Any problems with the hub slipping?
    Reputation: ernesto_from_Wisconsin's Avatar
    Quote Originally Posted by uno-speedo
    Make sure the hub's bolts are pretty tight. Near herculean strength, then you're good.
    Thanks Ernesto.
    Next question. I typically run 175mm cranks but am thinking about 170mm for that little bit more clearance. But its 5mm which is nothing really. And I assume the disadvantage is less leverage and more spinning. *Thinking out loud*
    Thanks Ernesto.
    I always run 175mm...70mm? like that's going to make a difference.
    808+909 = Party Good Time
    Reputation: chumbox's Avatar
    I find clearance problems are generally associated with the BB or the chainring not the crank so wouldn't bother changing the crank.
    I find the extra leverage is great when braking on a fixe.
    Go with the crank length your legs are used to.
    Reputation: Kaboose21's Avatar
    Go with 170. It's more important when cornering; you don't want your pedals to get hooked and take you down right in front of a car.
    Quote Originally Posted by Kaboose21
    or, you can learn when and how to hoopty the corners
    Reputation: OldHouseMan's Avatar
    You probably thought about this but...I'd think a front brake would be a must when running an eccentric hub. If that bad boy slips, you are in deep sh!t.
    I'm thinking of doing something similar too.
    I only ride bikes to fill the time when I'm not skiing.
    I run both 175 on my 26" wheels and 170 on my 29er.
    The clearance is better with the 170 but I have been riding everyting with the 175. It just take times to know your limit on the tight turns etc... I personally think that you should go with what you are used to.
    Dan
