Results 1 to 3 of 3
Thread: First SS Build
    First SS Build
    This week im going to start my first ss build and could use some input on a few things. The frame i'll be using is a surly 1x1. The part im not sure on is what crank, what would be a good one to start off with(brand/length) and being that I live in Michigan what gearing should I start out w/. I have been reading quite a bit on the forum and it seem that the white industries FW is the way to go w/ sram PC-7X chain. Im also thinking of using the surly hubs. Any input would help thanks.
    Eric
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    I like the xt crank
    [QUOTE=Funkyjive]This week im going to start my first ss build and could use some input on a few things. The frame i'll be using is a surly 1x1. The part im not sure on is what crank, what would be a good one to start off with(brand/length) and being that I live in Michigan what gearing should I start out w/. I have been reading quite a bit on the forum and it seem that the white industries FW is the way to go w/ sram PC-7X chain. Im also thinking of using the surly hubs. Any input would help thanks.
    Eric[/QUOTE
    I have a 180 crank,5mm bigger than my geared(seemed like a good idea at the time and still seems good.)
    I would start with cheap freewheels until your satisfied with gearing.
    34/18 is a good start
    pc-68 has treated me well.
    surly hubs are awesome,I can't say enough about mine although I have the old style.
    good luck.
    I've been inside too long.
    I agree with KgB, stick with cheap free wheels until you find a gear ratio that suits you, especially if you haven't SSed much before and because you live in Michigan and the riding their is a bit odd (flat). You may want to go to a WI freewheel later because if you ride in the muck and gunk you are bound go through them quickly. As for cranks, I just picked up a set of the integrated XT's in 180mm: stiff, light, and simple.
  1. SS Ghetto Style!
    By Acme54321 in forum Singlespeed
    Last Post: 10-08-2004, 10:26 AM
  2. Replies: 1
    Last Post: 04-15-2004, 08:52 AM
  3. should i go ss and HOW?
    By steve0512 in forum Singlespeed
    Last Post: 03-09-2004, 07:40 PM
  4. New SS build update....
    By donkey in forum 29er Bikes
    Last Post: 02-25-2004, 03:31 PM
  5. My first SS build ... almost there!
    By siochain in forum Singlespeed
    Last Post: 02-23-2004, 11:31 PM
