Results 1 to 11 of 11
    Reputation: davesauvageau's Avatar
    Fifteen G Cranks with EBB?
    I'm thinking about running the Fifteen G Crankset on my Rig with the Eccentric BB. Has anyone tried this?
    My motorcycle runs on infant blood
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    I run Ext. BB. on my Rig , I dont see why it wont work .
    Nov 2007
    I've got 15G's on my 29er SS w/ ebb and they were a piece of cake to mount up.
    Do you know what kind of EBB you have? I am looking to upgrade mine to the Bushnell one, but if it will work with my stock Rig, then I wont.
    Just built up my Singular and used 15g cranks. Set up was easy with the Phil EBB. No different than a standard BB actually. I wondered the same thing at first too.
    Reputation: Lets_Ride's Avatar
    I run Fifteen G's on my Raleigh XXIX with its stock EBB. Installed easily and no problems at all
    what type of EBB
    does the Raleigh use? I am wondering if the larger bearings will allow access to the Bushnell 5mm bolt.
    MTBDad
    MCM #47.867
    "Freedom has a scent like the top of a newborn baby's head" - Bono
    Quote Originally Posted by AndySTi
    The thing that I was worried about is the wedge bolt hole. With the Phil, you do not have to worry about that lucky!
    The Raleigh has an EBB with the set screws on the bottom of the BB
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    works fine on my Swift. Actually, better than fine. Fantastic.
    Just a regular guy.
    Quote Originally Posted by ~martini~
    Okay, so I know that the set bolt and pinch bolt style EBB's will work, I need the wedge bolt style. My Rig that I am installing it on has the wedge bolt that may be obstructed by the cups on the BB for the Fifteen G cranks. It would be dope to see if someone has installed Fifteen G cranks on a stock Rig......
