Results 1 to 8 of 8
    formerly Gobike69
    Reputation: Big Daddio's Avatar
    Fat vs. Skinny Tires
    I just put together a single speed bike and need advice regarding tire selection. Which is preferred for off-road riding, big tires (2.3) with lots of traction and rolling resistance or little tires (1.9 or 2.0) with less traction and less rolling resistance? Does it matter?
    Reputation: scottms33's Avatar
    both
    hey, you could always us one of each, i use an irc mythos xc 1.95" up front and i just took off a tioga 2.1" on the rear, it has a good mud flap design for better traction on those up hills...
    scott
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by gobike69
    Your choice, but I like 2.3+ on front, and 2.1 on rear. A little cush up front and mud clearance for the back. If I know it's going to be dry, and I'm going to a really rocky place, I may put a 2.3 on the back also.
    Derailleurs owned: 0
    Reputation: c0jones's Avatar
    What frame/fork?
    The best part about the trend toward fatter tires:
    -with the increased clearance you might be able to use 29er tires.
    My Bianchi D.I.S.S. is waiting for new wheels, on go the 700x44(29x1.7) Mutano Raptors!
    80 psi, now that's full rigid.
    C Jones
    80 psi
    I'm running the mutano 44's on my crosscheck at 45 psi without any problems as long as it's not really rocky.
    Not me
    Reputation: Surfpriest's Avatar
    disks?
    Does the DISS comes with disks and if so what did you do for 29ers? My SASS looks to be disk specific.
    D.I.S.S./S.I.S.S./S.A.S.S. are basically the same, except the D.I.S.S. is aluminum. To use 700x44 tires you will need larger diameter rims and longer spokes. A suspension fork would ruin the geometry, so this only works with rigid fork. Disc brakes means not needing the v-brake posts moved.
    Reputation: Mojoe's Avatar
    Bigger.....
    I like 'em big and fat
    Mojoe
    http://mojoe.unicyclist.com/
  1. why are wheels and 'spinning weight' important?
    By yellowwducky in forum Weight Weenies
    Last Post: 05-21-2004, 09:57 PM
  2. What size tires on your Fuel??
    By maddogdunn in forum Trek
    Last Post: 04-15-2004, 01:50 PM
  3. seeking Fat Albert, Big Jim or similar tire opinions
    By slowideclyde in forum Wheels and Tires
    Last Post: 04-06-2004, 07:48 AM
  4. hardrocks with fat tires
    By hardrockinG20 in forum Specialized
    Last Post: 03-26-2004, 03:55 PM
  5. Replies: 4
    Last Post: 02-02-2004, 02:01 PM
