Results 1 to 3 of 3
    Cthulhu fhtagn
    Reputation: Mike Gager's Avatar
    experimenting with SS chain tension with derailleur?
    playing around with my bike and ive shortened the chain quite a bit but there seems to still be quite a bit of slack. im just using the stock derailleur as a tensioner for now. how short should i make the chain to get the right tension?
    i didnt modify the derailleur in any way other then adjusting the b screw.the chain still wraps through it the regular way. is this the correct way of doing it?
    Cthulhu fhtagn
    well i ran it the way it was and it seems to work pretty good
    Dive Bomber
    Reputation: jackspade's Avatar
    I go as short as possible but not too tight, just give a little space for the chain to stretch.
    Give a little bit space for the spring to work a little bit since chain has tight spot so the tension is not fixed.
