Results 1 to 1 of 1
    etr-v & cog size help??
    This is my first ss conversion, I put on the etr-v tensioner with a 20 tooth cog and the teeth of the cog are only a few mm from the roller (no matter how I adjust it) and when the chain is on- the chain and cog are pushing the roller down. It looks like the biggst cog I will be able to run with this tensioner will be a 19.
    Should I have ordered the etr-d, it looks like the roller is further away from the cog and has anyone here put a 20 tooth cog on their etr-v?
    Thanks in advance.
