The Eternal Question
How many points of engagement would you say a standard fixed cog has? One? Infinite? Something else? What about for a bolt-on cog, like a TomiCog? Six points of engagement?
 Originally Posted by AZ.MTNS
Please someone explain to me (and others) how to insert a screen captured quote as my sig. line. TIA.
Fixed is never disengaged, so the question does not apply.
--sParty
disciplesofdirt.org
Remember who
you wanted to be.
 Originally Posted by riverrat
Jaybo... quit *****ing and move to Texas
Sooooooo.... How many POE is that?
Constant.
--sParty
disciplesofdirt.org
Remember who
you wanted to be.
--sParty
Constant.
--sParty
Soooooooooooooooo........... How many POE is that, then?
Sparty's answer is right, but if you want to push...the drive is engaged at every point ( and all the points between those points) so "infinate"POE or "B" on the multiple choice test.
Where the question breaks down is that nobody is realy hung up about POE while riding, it's minimizing degrees of crank rotation between engagement points that really matters . On the fixie the only play you might get at the cranks is from a loose chain.
Live the life you love!
For the fixed equivalent of a coasting bike the POE is based on the chain tension. It could be calculated based on how far many degrees the cranks rotate from tensioned backpedal to tensioned forward and the gear ratio. You could simplify the calculation be measuring the wheel's degrees of movements between the two tensioned states.
Someone once said, "there's no such thing as a stupid question."
That person was an idiot.
it all depends if your tires are hooking up or not. :P
Raised in a Chicken-Coop by Chickens
Haha, nice. I gotta use this
Who do they have to hook up with for this to happen?
Sizzlers mom would be a good start. YMMV!
What about umarth's mom, is that the next step up? Does umarth even have a mom?
I dunno... Though i did hear he has no belly button.
Oh, umarth has a mom alright.
3 POE.
--sParty
disciplesofdirt.org
Remember who
you wanted to be.
3 POE.
--sParty
That's it? I'd expect her to be more inventive than that!
how many roads must a man walk down before you can call him a man?
 Originally Posted by mack_turtle
how many broads must a man bed down before you can call him a man?
Fixed it for ya.
 Originally Posted by p nut
Uhhhh... = 1/0
I think it's more like lim(1/x) as x -> 0. Technically...
By ry36199 in forum Bike and Frame discussion
Last Post: 06-07-2011, 01:44 PM
Last Post: 10-13-2009, 11:15 PM
By funkle in forum Shocks and Suspension
Last Post: 10-10-2009, 03:48 PM
- You may not post replies
- You may not edit your posts
Forum Rules
