Results 1 to 7 of 7
    Reputation: 2big2ride's Avatar
    ENO Freewheel tooth wear?
    I picked up an ENO freewheel this spring, and upon inspection this weekend (due to a dry chain skipping). I see the small "edges" forming in the teeth of the sprocket. I have noticed there has been a slight bit of wear on the front ENO chainring as well. Is this normal? I took a small file to soften the edges. I have a ridden the bike pretty rough this year, but I would expect a little more out of a freewheel that costs as much. Has anyone else had similiar problems?
    cause it's fun
    Easy Fix...
    Keep your chain lubed. I've got one that's 2 years old, and has very little wear.
    bus driver wanna be
    I had to replace
    my freewheel and chain ring after 10 months of riding. I was a little irritated about that; until I began to think about how much riding I had done and how little work it was to maintain the ENO freewheel, none. I raced a good deal of muddy marathons and did a ton of riding and never once needed to open up the freewheel. If you ride, parts wear out, and to me, the fact that I only had to tighten my chain once in a while more than made up for the cost. Then again, had I been running ACS or shimamo I would have replaced the freewheel two or three times in the same amount of time or at least opened up the freewheel to clean it out and relube it. I will never run anything but ENOs, unless Phil Wood starts making freewheels. I have yet to find anything I can run for two years, so I just expect to have to replace drive train parts about every six months or so. For me the ten months was a very pleasant surprise.
    Just my opinion, for what it is worth, Ed
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Are you sure you don't have the chain too taut?
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Quote Originally Posted by cMc
    Can you replace only the outer part of the ENO freewheel? I just started using one after several years of the cheapies... ENO is sooo nice.
    Yes, you can replace just the toothed component.
    cMc
    cMc is offline
    since 1973
    Reputation: cMc's Avatar
    Jun 2005
    New question here.
    cMc
    cMc is offline
    since 1973
    Jun 2005
    Quote Originally Posted by Drevil
    Awesome. Thanks!
  1. Replies: 4
    Last Post: 06-16-2005, 11:06 AM
  2. Replies: 9
    Last Post: 06-16-2005, 07:37 AM
  3. Replies: 27
    Last Post: 06-09-2005, 09:35 AM
  4. What's causing my pad wear?
    By BigLarry in forum Brake Time
    Last Post: 04-05-2005, 03:23 PM
  5. 19 tooth freewheel
    By kenn y in forum Singlespeed
    Last Post: 03-25-2004, 09:25 PM
